Clonk!
Discussion in 'Tech/Mech General' started by Dodgey, Sep 29, 2009.
  1. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Any clever bike types here???:thumb:
    This is the bicycle bike, most of the time the faster/more load applied to the peddles produces a rythmic CLONK (caps 'cos it's loud!) that sounds kinda like some loon following me a belting the frame with a lump hammer.
    It sounds most like it's coming from the rear gear assembly, 7 speed/gears and I can feel it through the frame but nothings touching/fouling anywhere. Bikes only a couple of years old, any thoughts?
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,752
    6,251
    South yorks
    Hi it sounds like the gudgeon pin is loose or worn (holds pedals in position) take off the pedal arms examine grease and replace.:thumb: of course I could be wrong :Rofl1:
    terry
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    First point of call is the pedal crank bearings, rock pedals to test, there should be no play, even if there is no play it could be the early signs of bearing failure, play will eventually become evident, cant think of anything else that would cause a heavy CLONK as you describe
    Geo
  4. Andy 01424
    Andy 01424 Read Only Funster
    Aug 10, 2009
    154
    Hastings East Sussex
    Or the Chain is slipping on the gears if this happens during change and keeps trying to go to nex gear:thumb:
  5. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Terry,
    Gudgeon pin?....Cotter pin, it's the other type (can't remember what it's called) but no can't be that, mad push biker in my youth and remember the cotter pin shenanegans well, one bike just ate 'em, never did figure out why...
    Geo,
    Crank bearings, doesn't sound as though that's where the problem is though I must admit that was my first choice. No decernable movment as yet, might have to bite the bullet and strip the bugger and see. It's only a cheapy but I don't really want to replace at the mo, still seeing exactly how much use it's going to get as to how much to spend next time, that and have you seen modern bikes, hydralic disk brakes, 27 gears, adjustable suspension, toys toys toys:thumb::Rofl1:
    Cheers for the replies guys, any more?
  6. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Good idea but no chance, anal here has the gears set perfect, no slip and bang on adjustment.
  7. johnsandywhite
    johnsandywhite Read Only Funster
    Jul 29, 2007
    2,348
    15
    Doncaster/Spain
    :Smile: Hi Dodgey. I have the same problem with the Mountain Bike I bought from Walmarts 4 years ago. It has almost always done it. I believe it is the Crank Bearings. When I run Oil into the Crank it quietens down for a period before the sound returns. :RollEyes:
  8. Terry
    Terry Funster
    Dec 27, 2007
    10,752
    6,251
    South yorks
    Gudgeon pin?....Cotter pin :Rofl1: OK I will settle for cotter pin :thumb:
    either way it looks like you are going to have to strip it down :Rofl1: like it or not :Doh:
    terry
  9. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,800
    39,276
    If it is more or less every revolution of the peddle,, most probably what used to be the cotter pin,,, but on modern bikes you have an allen key on the end of the shaft (Pedal crank arm),, these are splined or square,, might need nipping up,, if it is the spline type whip it off as if it has been doing it for any length of time a splines might be worn on crank arm,,
    Modern bikes the cranks are alluminium and the shaft is steel,, hence the splines being/getting worn.
    The other alternative, on your gear wheel/cluster,,, if it happens in a particular gear,, it may have a crack on the thread on one particular gear wheel... 5/6/7 gears are made up of individual gears/teeth and they in turn are threaded onto a rachet body,, so you can remove sets of gear teeth and put what ever combination of gearing on that suits you,,
    If I remember correctly the threads are the oposite of the norm,, so as you do not unscrew when peddling.. bear this in mind if it is this and when replacing gear,,
    Think they are that cheap if it is this probably not worth the bother and just buy a new complete set..
  10. old-mo
    Oct 16, 2008
    12,800
    39,276
    No there not,,, "Normal Thread" :Doh:
  11. mondo
    mondo Read Only Funster
    Apr 29, 2009
    2,230
    1,105
    West Yorkshire...Halifax
    Remove the pedal crank and check the spindle you possibly have a cracked spindle..if not pack it with grease that should cure it
  12. Frank772
    Frank772 Read Only Funster
    Sep 15, 2009
    42
    Warwickshire
    May be worth looking to see if the L/h crank is bent (by dropping the bike) and
    hitting the chain stay.
  13. johng
    johng Read Only Funster
    Aug 15, 2007
    588
    Kent/Sussex UK
    seems a harsh way to check that, Frank :BigGrin: welcome
    I would have said bottom bracket bearings, or what is now in place of the gudgeons, usually a square shaft that now has worn cranks on..
    as said above a few times :RollEyes:
  14. John H
    John H Read Only Funster
    Sep 2, 2009
    254
    24
    Anglesey
    It could be a damaged or kinked link on the chain, or a damaged tooth on the crank?
    John
  15. Frank772
    Sep 15, 2009
    42
    Warwickshire
    Sorry I should have written caused by dropping the bike
    :Blush:
  16. johng
    Aug 15, 2007
    588
    Kent/Sussex UK
    :BigGrin: no worries
    sorry for being silly :thumb:
  17. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,909
    17,579
    YO11 2BD
    chuck it in a skip and buy a TOAD !!!!!!!! :Rofl1::Rofl1:
  18. Geo
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    Welcome to the FUN site Frank, it made me smile, written like a seasoned Funster :thumb:
    Geo
  19. Frank772
    Sep 15, 2009
    42
    Warwickshire
    Thanks Geo, I've also remembered that a gudgeon pin holds
    the piston onto the conrod :Doh:
  20. cyclingdoglucy
    cyclingdoglucy Read Only Funster
    Apr 27, 2009
    100
    lancashire
    bottom bracket
    just a educated guess is that the bottom bracket wants removeing & a sealed bottom brkt put in its place. you will have to remove the cranks & one of the bottom brkt cups has a left hand thread/:Doh:
