Clicking Fridge - Again, work around
Discussion in 'Fridges & Ovens' started by Dave and Ginny, Mar 29, 2016.
  1. Dave and Ginny
    Dave and Ginny Funster
    Jan 31, 2013
    1,360
    1,510
    Nottingham
    On an Aire in Velez Rubio, it's gloriously hot and fridge back to click click clickety click! If I hold gas knob in it stops and burner is lit, but let go and it's off again. I've managed to hold the knob in to keep it going at least till it gets cooler later. Essential supplies (beer) will get too warm if not.
    Any harm being done though, I'm wondering?
    Dave
  2. Badknee
    Badknee Funster
    Aug 25, 2014
    3,711
    15,931
    notloB
    Try turning the temp dial to its minimum (warm) for a few minutes once you get it lit. If we have ours turned right up to its coldest it won't stay lit. (y)
    • Like Like x 1
    • Useful Useful x 1
  3. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    4,792
    9,000
    Lorca,Murcia,Spain
    Can't help , but did the monthly car boot up Velez on Sunday .:)
    • Like Like x 1
  4. funflair
    funflair Funster Life Member
    Dec 11, 2013
    4,875
    5,143
    Guisborough
    Sounds like a dodgy thermocouple to me.
    Martin
    • Like Like x 2
  5. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,964
    2,793
    Kendal, Cumbria
    You'll do no harm. Holding the knob in pushes a small valve into position to allow gas flow. Once the gas ignites it heats up a clever device (thermocouple) that provides enough electricity to power a magnet that does what the pushed-in knob is doing. If the gas goes out, the thermocouple doesn't provide power, the little magnet releases and gas flow is stopped. It's worth checking the flame through the bottom vent if you can. It must heat the thermocouple - usually to red heat. Flakes of rust from the flue or a partially blocked jet can often look like a failed thermocouple. Mind you - so can a failed thermocouple :).
    • Like Like x 2
    • Informative Informative x 1
  6. Dave and Ginny
    Jan 31, 2013
    1,360
    1,510
    Nottingham
    Thanks, seem to work with knob wedged in to have at least kept it cool. Turned off at night for safeties sake. I can't get to see flame or access working parts as no lower vent on outside on our B544, lower vent in floor. I need to take fridge out when home and take a look. Looking back on service history, it seems it's played up and been looked at quite a few times. It's always been tempremental, sometimes if I drive a bit with it clicking it settles and stops! Bizarre!
  7. scotjimland
    Jul 25, 2007
    28,934
    25,589
    While holding in the valve manually will get it to work and cause no damage to the fridge..
    ... it's unsafe to leave it wedged in,
    if the flame gets blown out, gas will be building up behind the fridge... next time you try to light it may all go boom !
    personally I wouldn't do this.. would rather suffer a warm fridge
    • Like Like x 3
    • Useful Useful x 1
  8. funflair
    Dec 11, 2013
    4,875
    5,143
    Guisborough
    Im with @scotjimland on the safety aspect, if you are a DIY'er have a look ASAP and make it safe.
    Martin
  9. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,815
    1,882
    Warwickshire
    I think there has to be a lower vent for the fridge to work properly. On the B544 I think you will find it either behind the rear grey bumper or horizontal in the floor underneath.
  10. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,964
    2,793
    Kendal, Cumbria
    The safety issue is obvious & turning off at night a useful precaution. The small amount of gas from a fridge that's blown out will disappear via the drop vent anyway. If the 544 is like my 584 it has the lower vent through the floor. Interestingly on mine there is (almost) a lower vent in the conventional place (which on the 584 would be behind the bumper moulding). I say almost because it's there, cut out through the inner skin and insulation, but not through the outer aluminium skin.
  11. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,677
    5,831
    Mansfield,Notts
    Ok only half a Boom!!!! then:rolleyes:
    Thats a Boo still scary
    • Like Like x 1
  12. scotjimland
    Jul 25, 2007
    28,934
    25,589
    It may not be obvious to everyone reading the post.. hence my warning, and whether the risk is high or low, a gas safety device should never be over-ridden.. if it wasn't required.. it wouldn't be fitted..
    If there were a fire and or explosion resulting from it being overridden the insurance wouldn't pay out.. and if anyone were injured, the person who tampered with the valve would be held responsible... loss of life would result in manslaughter charges
    • Like Like x 1
  13. Dave and Ginny
    Jan 31, 2013
    1,360
    1,510
    Nottingham
    Completely agree with you Jim and I only ran it like that for a couple of hours whilst sat very near keeping an eye on it. It was very hot at the time and food in danger of going off quickly not to mention beers getting warm.
    It did seem to work OK though and If I turned the gas off whilst knob held in it did start clicking again but lit as soon as gas flowed again.
    Job to do when home!
    • Thanks Thanks x 1
