Cleaning Cassettk
Discussion in 'Motorhome Chat' started by tinkering, May 26, 2015.
  1. tinkering
    tinkering Funster
    Feb 25, 2009
    211
    885
    dorset
    the inside it the thetford cassette is beginning to look a tad iffy
    i had tried one of the bio prodouctfs with little success, it's been soaked in this solition for hours, then been given the large bottle brush treatment.
    My next plan of attack is a mild solition of industrial strength caustic soda.,
    soak for a hour them standing a safe distance blasting it with a Karkercher
    Any ideas please
    • Like it Like it x 1
  2. PaulyP
    PaulyP Funster
    Jul 29, 2011
    1,822
    3,132
    Manchester
    Only thing I can think is make sure you don't damage any seals.
  3. DiggerJon
    DiggerJon Funster
    Jan 25, 2013
    592
    5,721
    Dorchester, Dorset
    I found using the stuff that cleans and sterilises wine making and beer brewing kit quite effective - trade name is Chempro SDP but you used to be able to get an equivalent in most Wilkinson stores or home brew suppliers.
    • Like it Like it x 2
  4. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,886
    8,989
    NW England
    I steam clean mine by pouring boiling water and detergent in, closing all its orifices and giving it a good shake. There are enough small gaps for the steam to get out.
    You might get a result with some low grade Cola - Sainsbury's Basics at 10p a litre strips metal.
  5. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,454
    6,438
    St. Helens MERSEYSIDE
    Try some thetford toilet cleaner its made for the job , dont forget the seals are rubber and may deform with boiling water and dont shake too violently you may dislodge the internal mechanism .
    • Like it Like it x 3
  6. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,347
    13,202
    somewhere
    use calgone the stuff you use in washing machine stick some water in till nearly full drop three tabs in and levee for three days
    .if you can drive around with it even better
    bill
  7. trophychap
    trophychap Funster
    Dec 24, 2009
    735
    6,166
    bedworth warks
    Thetford Cassette cleaner? Gets all the scale off. Then afterwards use biological washing liquid instead of Loo Blue and you won't get any great build-up.
    White vinegar might do it, but I've never tried it.
  8. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    6,014
    9,440
    Lincs/Cambs border
    Cheap white vinegar in 4ltr containers from a cash & carry. Also does showerheads and kettles, etc, which suffer from limescale/calcium build up.
    Also good for descaling your stainless steel Truma boiler. (see instruction manual).
    Cheers,
    Jock.
  9. JockandRita
    Aug 2, 2007
    6,014
    9,440
    Lincs/Cambs border
    It didn't with mine, and it was in there more than 24hrs. :(
    Cheers,
    Jock.
  10. JJ
    JJ Funster
    May 1, 2008
    15,015
    27,014
    Vinegar.
    JJ :cool:
  11. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    We have 2 cassettes (y) each one has been done with Thetfords stuff once a year and are both fine-I also lubricate seals once a yr with Thetfords lubricant
  12. magicsurfbus
    Oct 11, 2010
    3,886
    8,989
    NW England
    I find that one of the best ways to deform the seals is to leave the cartridge fully shut when the MH isn't in use. My first seal went very quickly, whereas my second one has lasted 8 years.
  13. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,318
    8,026
    West Norfolk
    Our two 5 year old cassettes are spotless inside.
    I put it down to the use of biological washing liquid rather than the Thetford fluid.:)
  14. Wyaye wires
    Wyaye wires
    Sep 13, 2009
    3,831
    9,284
    Berwickshire
    A toothbrush and one's Memsahib...
    Of course if you still have servants...
    A good riding crop until they've got it spotless!!!
  15. icantremember
    icantremember Funster
    Sep 2, 2010
    5,456
    7,553
    Nr Watton in Norfolk
    Get someone with a small hand and a toothbrush to get their arm in there!:eek:
    Ww beat me to it:doh:
  16. vwalan
    vwalan Funster
    Sep 23, 2008
    7,674
    3,952
    roche cornwall
  17. tinkering
    tinkering Funster
    Feb 25, 2009
    211
    885
    dorset
    Thanks all,
    I'm trying some soda at the moment,it seems to be bleaching the scale but as yet has not moved it
  18. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,347
    13,202
    somewhere
    Soda wont shift it as it is alkali just like lime scale.
    You need acid vinegar even cheep cola but calgone will do the job I do my drains tanks and bog with it works a treat
    bill
  19. JJ
    JJ Funster
    May 1, 2008
    15,015
    27,014
    As mentioned in the one word post above!
    JJ :cool:
  20. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,347
    13,202
    somewhere
    sorry jj missed that one:doh:
