Class 4 or 7 MOT..........
Discussion in 'Tech/Mech General' started by dug, Oct 24, 2013.
  1. dug
    dug
    May 28, 2011
    82
    36
    Cheltenham
    Hi all,my son has recently bought a Year 2000 Renault Master 2.8 dti 3.5 ton passenger transport ambulance MWB that has a rock n roll bed and fixed table plus two belted rear seats carries 4 including driver,he has taxed it for a year in sept cost £225.00 states PLG with the existing MOT which is class 7.
    The logbook ( v5 ) states Motor Caravan which is the same as my Ducato maxi motorhome ,but my Ducato at 3.5 ton is classed as class 4 MOT,so the question is how do I change the Renault from class 7 to class 4 or is class 7 easier ?
  2. Traveller_HA5_3DOM
    Traveller_HA5_3DOM Read Only Funster
    Jul 13, 2012
    428
    326
    Following the Sun
    There is only one place to ask and this is the DVLA. I would say write to them, that way it is logged in the system and providing you do not quote your phone number you will get a written reply. It seems on the face of it that it has been wrongly entered in the test database as from your description of the vehicle it should be class 4. You could also ask the last owner as to why it was tested at a class 7 testing station, he may have just received wrong advice.
    Keep the site posted on your outcomes.
  3. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,596
    7,880
    Was the van tested as class 7 and then after converted and re- registered as a motorcaravan.. If thats the case then after re classification it only needs a class 4.. Is this the first MOT after the conversion.. ?
    Why not pop to a test centre, see what they say.. All the facts point to it being a class 4.. The most important bit is that wording "motorcaravan" on the V5
  4. dug
    dug
    May 28, 2011
    82
    36
    Cheltenham
    :thumb::thumb: The last owner is no longer in the country,i will take it to MOT station with logbook and see what they say ,thanks chaps....Doug.
  5. Gromett
    Gromett Funster
    Feb 27, 2011
    8,171
    14,975
    UK
    When I had an 8.4T bus I got it done as a class 4.
    All four MOT testers I have used over the last 5 years say they test as the vehicle appears to them. They don't look at the log book or previous MOT class.
    Motorhomes no matter what the base vehicle is class 4 :thumb:
    If you current MOT tester is refusing to do it as a class 4 change MOT tester.
    • Like it Like it x 1
  6. Traveller_HA5_3DOM
    Jul 13, 2012
    428
    326
    Following the Sun
    The problem is if it is on the DVLA system as a class 7it will come up on the computer link at the testing station. They need to bring up the record using your vehicles registration number in order to issue another certificate I will be very surprised if they then carry on and test it as class 4.
  7. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    4,018
    6,543
    Roobarb land
    I converted a motorbike to a trike and the mot tester just updated something on his system and tested it there and then
    Did have to go after to dvla though for a change of use inspection to get log book changed over
  8. Gromett
    Gromett Funster
    Feb 27, 2011
    8,171
    14,975
    UK
    They did for me.
  9. estcres
    estcres Read Only Funster
    Oct 9, 2007
    1,301
    766
    Sunny Bournemouth
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,089
    17,759
    YO11 2BD
    some things can be changed at the mot station.
    my rv was tested as class IV which is correct, but the fuel type was listed on the system as diesel.
    the tester simply changed it to LPG....pretty obvious it isnt diesel :Doh:
    this year he questioned it again...knowing it is LPG/petrol.....it was still listed as diesel but i saw him change it last time.
  11. estcres
    Oct 9, 2007
    1,301
    766
    Sunny Bournemouth
    So what you are actually saying is:
    It can't be changed at the station.
  12. john kyte
    john kyte Read Only Funster
    Dec 17, 2013
    60
    42
    Salisbury
    My Ford transit twin wheeler--about 3.5 tons now used as campervan still registered as ambulance is tested class 4
  13. Landy lover
    Landy lover Funster
    Jul 11, 2009
    2,067
    4,373
    Zummerzet
    MOT tester should know what class he is testing and if the information on the MOT system is wrong can change it. Rule is - is the vehicle to be tested compliant with being built / converted for living ie fitted means of sleeping /cooking/ etc. and preclude its use as goods carrying vehicle ' then its class 4.
  14. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,608
    3,420
    Telford, Shropshire
    MOT tester should test the vehicle "as presented" which means if it looks like a motorhome to him when presented for test then it gets tested as such and ALL motorhomes, regardless of weight are class 4. You don't need to do anything till the MOT is due and then when you present it for test you simply make it clear its a motorhome and falls into class 4, not all testers are aware of this, especially the newly qualified ones.
    D.
