Cigarette socket supply getting hot (1 Viewer)
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
Is the cig socket meant to get hot if I am running a coolbox and a satnav off of it?
The contacts are clean both sides, the plug fits in properly and makes a good contact.
If I pull it out after 5 mins the plug is very hot.:Eeek:
jb0371old
465
408
Norfolk
Autotrail
1 year
I would assume the coolbox is drawing a lot of current, doubt its the sat nav
tonka
10,829
21,525
Cannock, Staffs
A class Burstner 800
Since 2000
Agree, cool box could be taking a lot of power, check the wattage..
A lot of cigarette sockets are limited to 120w..
J
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
Just seen on the motor label-- 5.5a 12 v, it used to work ok in a car years ago.
Maybe it`s had it`s day, hot beer from now on then , the fridge is full :cry:
John & Joan
1,425
774
Darlington
10 years this time
I've had this with just a mobile phone charger. It turned out that the plug was not fully home and was sparking to make contact. Joan said she could hear a buzzing noise that I couldn't but when I touched it, the socket and plug were hot.
When I had a good look at the charger it did not have a spring to push the centre contact down to the centre contact. It looked identical to other plugs I have used in the past. I had recently purchased it from an online firm but was obviously sub standard.
I bough another from Maplin and it works fine in the same socket.
J
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
Tested the coolbox in a car , and works ok.
Seems the problem was with the Halfords multi socket adaptor, the plug from it seems to have a low rated fuse which seems to heat up when used.
Off tomorrow to get a beefed up adaptor:thumb:
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
Have a look inside the plug there is possibly a fuse inside it which may have some corrosion on it - if so remove it and clean it both ends and possibly use a very small amount of Vaseline to stop further corrosion
G8WVW
92
67
Cumbria
C class
Since 1990 on/off
Cigarette lighter socket/plugs are electrically/mechanically RUBBISH!!
Supposed to be good for 10-Amps ... more like 3-Amp at best!
Seriously look at something better!
Hella socket, a full/proper 16A.
Anderson PowerPole (excellent) 35A.
Direct connection to the battery ... +++A.
Good luck!
43,323
49,428
Good luck!
I use Hella after melting a 10amp fag lighter type sockets running an LCD 22" tv and a 12v sat receiver through a dual adaptor.
adaptor got so hot it melted the fag lighter socket.
now have separate 16a Hella sockets
