CI motorhome - habitation electrics gone down (1 Viewer)
Al68
9
Kent
CI Carioca 644
Since 1980
My 2005 CI Carioca has lost all electrical supply on the domestic side - no 12 volt fridge, no lights, no water pump etc. I have checked fuses on the control unit circuit board and all ok. I have unplugged supply plugs to the board and found 12.7 volts coming from both leisure/house battery and engine battery. I have checked for loose connections or poor contact but nothing obvious was found.
I have been told by a CI dealer that it is not uncommon for the main circuit board to fail and so suspect this is the problem. A replacement costing £300 takes 6 weeks to come from Italy!
Anyone have any other ideas; know where to get a circuit board tested and repaired; buy new or second hand; replace with alternative; etc?
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
not familiar with your van/electrics but on mine domestic electrics cut out when ignition turned on could be the relay that controls that operation?
Terry
11,932
9,078
Lincolnshire
Can't remember ;)
BUMP :ROFLMAO:
personally I would get a auto sparky to check it out :thumb:Then look at alternatives :winky:
terry
Les
Apr 18, 2008
301
4,139
Seaford
Low Profile
I have CI cipro and when I hade big Voltage drop after lots of looking found a weak fuse good luck
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
you don't say how long you have owned the van, if not long then its possible its just a switch problem. !2v fridge should only work when the engine is running and will only maintain the temp not cool it down.
Again possibly a switch problem, failing that a fuse near the battery.
Last resort is circuit board, does power reach it?
656
1,052
290
The universe
There is a big Red switch by the passenger seat / door, is that fully on?
ubuntu1
155
44
Derbyshire
PVC
since 2006
electrics failed
Take a look at the MCEA web site and get a local engineer out to help you. It could be a faulty PCB but it could be many other things.
