Ci autoroller 6 berth
Discussion in 'CI Motorhomes' started by mark e, Oct 29, 2007.
  1. mark e
    mark e Read Only Funster
    Sep 29, 2007
    242
    Rhondda Valleys, S Wales
    Had my motorhome just 2 days and at the back i have an external locker, which is under the back l shaped seaten area/ double bed. Noticed that the drop part of the locker behind a covering the wood is all damp.
    I have been out tonight with 2 hairdryers trying to dry it out, it worked because water was driping out. I have bought some translucent silicone and filled in the gaps. will this work ? Anybody elsee suffered this problem ?
  2. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
    You might be sealing damp in.
    Damp is a major killer of camping vehicles.
  3. justme AKA Grath
    justme AKA Grath BANNED
    Aug 16, 2007
    479
    Hi Mark,
    Very sorry to hear your problems.
    I do not know if this info will be of any help to you however this year I have meet 2 C I owners that have told me of water ingres problems.:Eeek:
    They both had water coming in around a window and it was found in both cases that the window frames had not been sealed at all.:Eeek:
    Now I know that yours is not a window, but could it be coming from a window and travelling or the locker door frame?
    EDIT*******
    In both cases it was the Kitchen window!!!!:Eeek:
  4. mark e
    Sep 29, 2007
    242
    Not as serious as those, windows no problem at all/ No smell of damp inside, ckecked all behind cushions etc. Definatly only the drop down locker. Dry as a bone inside back locker department and i can see what the problem is. no silicone where fibreglass meats metal frame. Have sealed hopfully, no damp left in there !! only time will tell ...
  5. justme AKA Grath
    Aug 16, 2007
    479
    Sealing
    If you have found it, and I hope you have,:thumb: it seems that C I are not very good at sealing things!:Eeek:
  6. Road Runner
    Jul 26, 2007
    14,196
    1,459
    Europe
    Even if it's nought I would mention it to your dealers just if........................
  7. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    Just for the record and my opinion only,using heat to dry out a Motorhome is next to useless as all your doing is moving the water about by evaporation it will condense somewhere else, ie stay in the van
    Far better to buy a small cheap dehumidifier and keep van on hookup 24/7 you will be amazed at the amount of water you remove
    Geo
  8. mark e
    Sep 29, 2007
    242
    anybody else tried using a dehumidifier in their van ?
    Like i said it's not part of the interior but the drop down door anyway. as i was using the hairdryer the water was dripping out of the flap, so im happy with what ive done. I will though keep an eye on it over the next few weeks as the weather gets colder.
    Please keep your comments coming though as this has caused me some concern.
    im just thankfull that it was nor inside the van :Eeek::Eeek:
  9. Road Runner
    Jul 26, 2007
    14,196
    1,459
    Europe
    I have used dehumidifiers and heaters and bith are excellent:Wink:
    It is only since June my van is now in storage:cry:prior to that always plugged in at home with the heating on.
    Dehumidifiers are so good it is said that unscrupulous dealers use them prior to showing a damp van:Wink:
  10. gfp
    gfp Read Only Funster
    Dec 29, 2009
    HI mark e
    I am new to this site, so forgive me if you have already solved your prob.
    I have a ci riviera 181-year 2002.
    It sounds as if the backs of our motorhomes are the same.
    If this is so, ours has a wide locker door across the back (hinged to open down) which gives access to under rear u shaped seating.
    I have found that because of the length, and the fact that the two retaining locks/catches are so far apart, that, now and again the locker door becomes bowed outwards in the middle, and the catches become loose.
    A simple fix is to hold both ends of the door and gently ease the middle section back into shape, and tighten the catches, held on by the center screw. this makes for a mutch better seal along the top of the door.
    Hope that this is of some help
    glen.
  11. grasscutter
    grasscutter Funster Life Member
    Oct 11, 2009
    1,369
    2,277
    East Wittering. West Sussex.
    We permanently keep 3 moisture traps filled with crystals in our motorhome. I have fitted them with velcro strips to stop them moving around. You would be amazed even in a dry van how much moisture there is just from living in the van. We also run a very small dehumidifier when leaving the van on storage on our drive.We never suufer from any form of dampness/stale smells.
  12. tucker_j
    tucker_j Read Only Funster
    May 26, 2009
    87
    Kent
    We have a CI Riviera 171 and while the layout is different this may shed some light on your problem.
    If you look at the rubber seal which is fitted to the actual locker door, held in place by a grooved outer edge on the locker door frame it does not cover the entire door as gaps are left for the hinges. We get water finding it's way into this gap and then filling up the groove - beneath the outer rubber seal but not actually penetrating into the locker as the inner seal around the door frame prevents this.
    However, if left for too long I suspect this would eventually penetrate the locker. I open the locker door every few days during rain to 'drain' the groove out. So far we have been unable to find a more permanent or effective cure.
    Funny think is the habitation door is exactly the same design but doesn't suffer from the same problem,
  13. mark e
    Sep 29, 2007
    242
    Had my door re- hung, or realigned, new board in the drop down door, new rubbers changed TWICE, from bigger rubbers and back to direct replacement size. £300 pounds later, not as bad, sadly the damage was done as old keeper did not relise the problem.
    But now i keep towels placed down acroos the full width of the motorhome and check DAILY.
    99 % of the time it is dry but somtimes i think depending on the prevailing wind the towels get slightly damp.
