Christmas conundrum
Discussion in 'Motorhome Chat' started by motorhomewave, Dec 19, 2012.
  1. motorhomewave
    motorhomewave Funster
    Jul 17, 2009
    135
    51
    Am I being silly or have the designers at Elddis failed to try to use a TV on 12 volt with the aerial plugged in to the socket provided for outdoor connection. The two plugs will not go in at the same time ! the 12v plug covers the aerial input. I could plug the aerial straight into the TV but this necessitates bringing the cable in from the sky window thing and leaving it slightly open and in late November in the Highlands it was pretty cold ! Is changing the unit the only choice ?
    • Like it Like it x 1
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    Hmm. Looks like a silly design but likely to be the socket manufacturer rather than Elddis. It would be worth removing the plate to see if the plug socket can be popped out and swivelled round.
  3. hilldweller
    Dec 5, 2008
    27,551
    26,646
    Macclesfield
    The two connectors appear to be fitted to a backplate, I wonder if they would pop out and could be swapped over or turned sideways.
  4. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,396
    5,423
    East Sussex 01-580-881288
    You could 'modify' the plug, its only 12v
    Peter
  5. motorhomewave
    Jul 17, 2009
    135
    51
    Modify
    "Modify" Peter......... (big hammer)
  6. hilldweller
    Dec 5, 2008
    27,551
    26,646
    Macclesfield
    Hacksaw, but don't. There's no way they would design it so it cannot work, almost certainly some dimwit has assembles the two sockets the wrong way round.
    Or, tiny chance, there is a slim plug with rear exit, I can't find one.
  7. Campercaillie
    Campercaillie Read Only Funster
    Jun 23, 2012
    1,178
    2,127
    Scottish Highlands
    No trouble on mine, but the 12v plug is certainly not as bulky as that featured in your photo. I'm sure you could source a suitable alternative for a couple of pounds.
  8. scotjimland
    Jul 25, 2007
    28,939
    25,628
    Smaller 12v plug from camping shops
    [​IMG]
  9. motorhomewave
    Jul 17, 2009
    135
    51
    Thanks all
    Thanks all for advice, I shall unscrew the plate and see what lies beneath. I may not need a crematorium if this goes wrong, wish me luck ! :BigGrin:
  10. hilldweller
    Dec 5, 2008
    27,551
    26,646
    Macclesfield
    Death or Glory !
  11. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    Why not unscrew the 12V plug and remove the cover from the plug,.
    Drill a small hole (of sufficient diameter for the cable to pass), into lower part of the cover to allow the wires to come out of through the cover of the plug instead of the existing cable entry,
    Reconnect the wires in through the new hole,
    Now you can plug in the 12V plug avoiding the antenna socket.......
    5 minute job.... :thumb::thumb:
  12. callumwa
    Jan 16, 2011
    4,113
    4,518
  13. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Pull leisure fuse
    Remove the screw covers on the wall socket.
    Disconnect cables
    Push out connections, swap and reinsert.
    Reconnect cables, screw back into wall and replace screw covers.
    Pop your fuse back in and you are sorted. Aerial above socket.
    :thumb:
  14. GJH
    Aug 20, 2007
    27,349
    34,968
    Different type of plug, Jim, that fits a different socket.
  15. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    with the power off just see if the plug will fit upside down if it will just re-wire it and use it that way up.
  16. GJH
    Aug 20, 2007
    27,349
    34,968
    They're only one way Andy. One pin is larger than the other.
Similar Threads
  1. Dazzlin
    13
    361
  2. Ksagic
    5
    104
  3. alfandM
    162
  4. meggie
    58
    1,904
  5. Janine
    305
