Chris Green charging machine
Discussion in 'Motorhome Chat' started by Terry, Jan 12, 2013.
  1. Terry
    Terry Funster
    Dec 27, 2007
    10,752
    6,251
    South yorks
    My mate has just given me a CG type charging machine :thumb:
    I asked him to get me a small engine about 3 mths ago telling him what I intended to make or have made. He got me a small Honda engine from a water pump for 20 quid from the sales rooms :thumb: within a couple of weeks which has been sitting in the garage along side a 150 amp alternator waiting :BigGrin:
    This ready built one comes with a Briggs and Stratton engine, dry clutch/direct drive to the alternator :thumb: It has made me rethink about the Honda one because I was thinking along the line's of belt drive but the dry clutch looks the way to go :thumb:
    Terry
  2. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,623
    7,500
    england
    sounds good! but the reason i went for belt drive instead of direct drive is gearing, my charger run's at three to one,that's to say for every 1000 rpm the engine does, the alternator does 3000 ,instead of one to one you get with direct drive so less rev's same output:thumb:
  3. canopus
    canopus Funster Life Member
    Nov 27, 2010
    3,124
    3,485
    Lincolnshire
    all sounds a bit testicle to me :Rofl1:
    • Like Like x 1
  4. Terry
    Terry Funster
    Dec 27, 2007
    10,752
    6,251
    South yorks
    That was my original thoughts Chris :thumb: but the clutch thing looks good and neat :Smile:The whole thing needs tyding up and I will probably fasten it all in a case/box it all in come warmer weather :BigGrin: At the moment all I can say is it works :thumb::Smile: no idea how to measure how many amps it throws out but it charges at 13.5v plus :thumb:If it warms up a bit I will venture out and take a pic or two :Smile:My mate was watching for another engine for me at under £20 but as soon as he saw this he knew what it was from my description :thumb: and at a good bit less than 20 quid he bought it for me :BigGrin::Wink:
    terry
  5. Terry
    Terry Funster
    Dec 27, 2007
    10,752
    6,251
    South yorks
    Here are the pics :thumb:as you can see somebody clearly used an old cylinder type lawn mower for the parts :Smile: and a bit of the old grey matter :thumb:
    terry
  6. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    Ive a feeling you are going to put the silence back into suitcase generators :Rofl1:
    • Like Like x 1
  7. Terry
    Terry Funster
    Dec 27, 2007
    10,752
    6,251
    South yorks
    Will have to do something Geo the only place to lift it from is the exhaust :Eeek: no doubt that will get very hot :Sad::Wink:
    Terry
  8. tofo
    tofo Funster
    Oct 1, 2007
    6,647
    6,427
    Kirby cross further from londin
    that exhaust pipe looks like a gas meter fitting
    possibly 1" bsp or 3/4 bsp with a brass nut at other end
    possibly 5 light or 10 light nuts
    :thumb::thumb::thumb:
  9. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,623
    7,500
    england
    the engine is off a suffolk punch lawnmower the altanator looks like a lucas A127,the control panel looks like something from a tree,and all put together by a company called heath&robinson.:Rofl1::Rofl1: date mid 70s, value? less than £20:Rofl1:
  10. Terry
    Terry Funster
    Dec 27, 2007
    10,752
    6,251
    South yorks
    Yep I thought the same :BigGrin:
    Didn't cost me a penny :thumb: and did cost my mate a lot less than £20 :thumb: When it gets warmer I can use the Honda engine and 150 amp alternator off a Citroen or get a 200 amp alternator instead
  11. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,623
    7,500
    england
    if you use a 200 amp alternator you will need a 3 to 5hp engine and the weight becomes a problem,even a 150 alt will need a fair bit of hp to run it,been there done that:Doh:
  12. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,889
    somewhere
    machine mart sell good ones under £100 save all that messing-about we love the one we have and not that noisy:thumb:
  13. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,623
    7,500
    england
    you cannot buy a good 12v genny under £100.
    you cannot buy a good 240v genny under a £100,you can however buy a 240v piece of tat,that mascerades as a 240v genny for under £100,but would you realy want to plug it into a £50.000 motorhome loaded with the latest electronics???
    • Like Like x 2
  14. Terry
    Terry Funster
    Dec 27, 2007
    10,752
    6,251
    South yorks
    Hi Chris :thumb: the Honda engine is from a water pump -no idea on size- and the alternater turns by hand quite easy so how will a 200 amp one need a bigger engine ? I would think it takes a lot more effort to pump water than turn the Alt?
    Come to think about what you are saying I often wondered why they don't fit 2 or 3 or even 4 alts to a small engine to produce power for leccy cars ? you could well have answered that for me :BigGrin:
    I think you are on about small genny's :Doh::Wink:Not near as adverturous :BigGrin: or close to sticking power into battery's-genny's give out max 8 amps and if you plug the vans onboard charger into it most vans are fitted with 12/20 amp chargers,(very few come with much bigger)CGGM comes with a small 50/75 amp alt to charge the batts :Wink:
    Having said all this in the 12 yrs or so M/H ing I have never needed either a genny or a Green machine :Rofl1: it's more of a challenge/wanting to make one for the fun of it :thumb: I cannot see me ever useing either or even carrying them in the van.:BigGrin:The only practical use I can envisage is when the odd friend /fam member wants a jump start -give them that and send them on there way :Smile::BigGrin: :Doh:forgot they would probably need a lift to there none starting vehicle so it looks more like the truck and jump leads :BigGrin:
    terry
    • Like Like x 1
  15. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,889
    somewhere
    we find it works fine with surge protection and if i could afford a 50'000 motorhome i could certainly afford a Honda generator in sted of just boging something and the under £100 generator conformers to all current legislation regarding portable generators duse that pice of scrap
    and i did not at any time say it was a good genorator i sad i that it ok for us and we like it
    my comment wasn't meant with any malice but seems you have taken it that way
  16. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,623
    7,500
    england
    terry! all alternators turn easily by hand,its when you put them under load,they become a whole different animal,needing lot's of HP,to produce power:thumb:
    • Like Like x 1
  17. Terry
    Terry Funster
    Dec 27, 2007
    10,752
    6,251
    South yorks
    Cheers Chris :thumb: like I said in my other post you have answered my question.:thumb: I did not know they got harder to turn :Doh: but do now :thumb:
    It got me thinking a few months back when I saw a leccy vehicle (ran out of juice ) with a main agents van and jump leads connected,obviosly giving a boost to get it home.
    I thought of your machine and how handy it would be to carry one in the boot :thumb:Hence my thinking shove 2 or 3 alts on one and away you would go :BigGrin: not that simple ?
    Another use I thought about was for generating 240 v power off grid ie 10 x 12v batts connected to give 240v then blast with GM with 2/3 alts to rechage :Smile: but alas from what you say it won't work :Sad::Doh: EDIT it will /would work but not as I thought - back to the drawing board :BigGrin:
    terry
  18. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,623
    7,500
    england
    mine gets used quite a lot,by neighbours with flat batteries,and one even charges up his battery on his saw bench,that he uses for cutting up tree's for logs:thumb:its fitted with a huge kohla engine with a combined starter-alternator but the alternator side give up years ago so he uses my little machine now and again just for chargeing:thumb:
  19. Emmenay
    Emmenay Read Only Funster
    Dec 11, 2011
    364
    274
    Anywhere
    This is correct, as an example if you have a loose/weak alternator drive belt the chances are it will squeal when you load it with headlights/heating switched on etc, proving it is working much harder. :thumb:
    • Like Like x 1
