chip or map
Discussion in 'Motorhome Chat' started by ukbill, Mar 20, 2013.
  1. ukbill
    ukbill Funster Life Member
    Nov 3, 2011
    4,997
    4,920
    benidorm
    i have a carioca 694 fiat ducato is it worth either mapping or chipping the engine and if so wat does it do i have heard about it but got no idea wat it will benefit me :Smile:
  2. ukbill
    Nov 3, 2011
    4,997
    4,920
    benidorm
    bump
  3. Landy lover
    Landy lover Funster
    Jul 11, 2009
    2,089
    4,656
    Zummerzet
    My opinion for what its worth is remap but do it from a local reputable source that will hold your original settings in case you are not happy with the results. Most chips work by altering the times on the injectors and very little else - a remap is just that - it should take into account the size and bulk of the vehicle - its normal running weight plus any add on that affects air drag. It should then also take into account the 'normal' driving ie mainly motorway etc. The remap will then take in all aspects of the engine from throttle response to air flow meter - water temp - oil temp - as well as the injectors etc and literally remap the way the engine works - the result should be a more responsive more powerful engine and driven normally should return a better Mpg. No way an off the shelf fit all chip can do that.
    Always remember you should notify your insurance company of fitting a chip - failure could result in finding you are uninsured in the event of an accident
  4. Gooney
    Gooney Funster
    Jun 2, 2010
    4,778
    7,876
    Flintshire
    Why do it if you don't know if you need it?, engine manufacturer has set up the engine for overall average use.
  5. ukbill
    Nov 3, 2011
    4,997
    4,920
    benidorm
    because i have heard its a good thing to have done and can save money
    and i like doing things even though i got no idea what they do :Laughing:
    • Like it Like it x 1
  6. ukbill
    Nov 3, 2011
    4,997
    4,920
    benidorm
    thanks Landy lover its ok i would get my local garage to sort it its not something i would try myself
  7. Gooney
    Gooney Funster
    Jun 2, 2010
    4,778
    7,876
    Flintshire
    Whoops sorry Bill, I only read your post I should have noticed you signature:Doh:
  8. camocam1
    camocam1 Read Only Funster
    Aug 28, 2012
    1,112
    783
    Elgin,Moray,Scotland
    re mapping is not something your local garage could as normally done by specialist companies, if you bought a chip then yes they could fit it for you
  9. hilldweller
    Dec 5, 2008
    27,769
    26,857
    Macclesfield
    You won't save money, if you use the extra power you'll lose a lot.
    I had it done because ours needed lots of down changes on hills, now it pulls up hills much better. No change in fuel if I drive sensibly but when I first had it done I got carried away on my own on a trip to Scotland and got down to 20 mpg from a normal 25 mpg.
    But if it ain't broke, don't fix it.
  10. ukbill
    Nov 3, 2011
    4,997
    4,920
    benidorm
    ok brians advice now taken no mapping and no chipping leave well alone seems to be the thought for today thanks all
