Chinese sat nav reversing camera
Discussion in 'GPS Navigation' started by Mattyjwr, Jan 17, 2014.
  1. Mattyjwr
    Mattyjwr Funster Life Member
    Aug 18, 2013
    1,881
    3,289
    Beds
    I am having fun with my new Chinese sat nav. Seems to be working well.
    I've seen that several people have bought the reversing camera that can attach to the sat nav.
    Does anyone have any details?
    • In particular, any ideas on the viewing angle?
    • What kind of connections does it have?
    • How long are the cables?
    • Does it have night-view?
    • How quick is the change between camera view and sat nav?
    Thanks,
    M
  2. Tootles
    Tootles Funster
    Sep 14, 2013
    9,136
    32,626
    Lancaster
    I can answer a bit of that. The viewing angle seems to be quite good, but I haven't mounted it in situ yet, so not 100% sure.
    The bit to the satnav, (ie the front bit), plugs in between the 12volt supply and the unit. So, the cable from the 12 volt ciggie lighter socket goes into the front camera Bluetooth receiver, which then plugs into the satnav....make sense?
    The rear unit cables are very long, you wouldn't have a problem connecting the camera to the reversing light, (which operates it).
    It has a ring of LEDs around the camera lens. Not sure just yet how effective that will be.
    As soon as you select reverse, the unit changes from directions to camera. When you come out of reverse, it changes back to the direction screen.
    Will know more when its fitted. :Smile:
    • Like Like x 2
  3. jaytee74
    jaytee74 Read Only Funster
    Dec 5, 2013
    72
    37
    durham uk
    chinese sat nav reversing camara
    just wanted to add , used my chinese truck--lorry sat nav for first time this weekend traveling into the north pennines it gave early warning of all narrow or low bridges and narrow roads in good time for me to take alternative route if chosen. in truth it was first class (fantastic) well worth the £48.00 i paid for it. re --reverse camera i have just fitted one of these also not a combined unit but an independent unit. BUT i connected it to my rear lights so i can and do use it as a rear mirror which means i can see the blind spot immediatly behind me the spot where rear mirrors cannot cover also if someone tailgates me (ie driving to close) i can read there REG no and if need be phone traffic police with details without the driver behind been aware. and of course when i want to reverse i just switch my lights on. if i want to switch off whilst traveling at night !!!! since i have it connected through my cigarette lighter i just unplug it. i hope this is of interest to someone. jt
    • Like Like x 1
  4. Mattyjwr
    Aug 18, 2013
    1,881
    3,289
    Beds
    I have wired my wireless reversing camera to my number plate lights so that it comes on with the side lights. I may be replacing it with a wired camera as the wireless signal interferes with the radio.
  5. jaytee74
    Dec 5, 2013
    72
    37
    durham uk
    chinese sat nav reversing camera
    hi matty j had similar problem cured it by extending arials. jt
  6. hoot007
    hoot007 Funster
    Aug 19, 2010
    271
    271
    trawden lancs
    We have been looking at these on Ebay but they are asking £62 can I ask where you got yours.
    Thanks Joyce
  7. kex66
    kex66 Read Only Funster
    Jan 29, 2012
    166
    202
    cheshire
    I'd be afraid a Chinese sat nav/ reversing camera would send me the wong way......................sorry, I'll get me coat........:BigGrin:
    • Like Like x 2
  8. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,472
    884
    South Glos
    I tried connecting my existing reversing camera to the satnav using the av input. It showed the image ok but didnot switch back to the satnav when the camera turned off it just stayed frozen on the last image.
    Switching the satnav power off and on did not make any difference. As long as the camera was plugged in, even with the camera turned off the unit only showed the last image and I could find no way of exiting the display to get back to satnav. Only unplug the camera lead.
    So not very successful.
    Lunarman
  9. Tootles
    Tootles Funster
    Sep 14, 2013
    9,136
    32,626
    Lancaster
    Just a thought. The camera itself contains a number of LEDs. If you have it on at night, your showing a white light to the rear. If you unplug it, the GPS wont work. If you wire and switch the supply, you will have to hard wire it from the cab.
  10. Terry
    Terry Funster
    Dec 27, 2007
    10,759
    6,253
    South yorks
    The LEDS will be red :Wink:
    Any one got any links to sat nav and a wired camera ? also I remember seeing a rear view mirror sat nav and camera but cannot find them now :Doh: again if anyone has a link ? much appreciated :Wink:
    terry
  11. jaytee74
    Dec 5, 2013
    72
    37
    durham uk
    • Like Like x 1
  12. jaytee74
    Dec 5, 2013
    72
    37
    durham uk
    hi tootles i thought that but it does not happen as i use wireless connection so camera and sender are connected to rear lights independent of screen. Screen and receiver are connected to cigarette lighter on dash thus independent of camera. Everything works via wireless have clean clear picture 95% of the time but do experience occasional interference from overhead telephone or electric cables but have eliminated some of this problem by extending ariels both on sender unit and receiver unit. If there had been an issue with white light from LEDs im sure a little bit of my good ladies waterproof nail polish could have dealt with it although the site of her clinging onto the tow bar with one hand whilst shielding the LEDs with her red nail polished other hand whilst wearing roller skates would be a sight to behold/ pps in case of confusion my GPS and reverse camera are totally independent unit( NOT COMBINED) hope that clears things.
    • Like Like x 1
