Chinese Sat Nav - Help for the technically inept..... (1 Viewer)
Aug 27, 2014
1,910
3,928
Shropshire
McLouis Tandy 640+
Since 2014
Well, not totally inept, more just never had the inclination to learn properly!
I've got one of the Nozatec truck sat navs, was looking to add a few bits before going abroad in a few weeks.
Firstly, French Aires - I see there is a file in the resources section that says:-
this zip contain the kml and bmp files for the aires poi for the chinese satnav.
extract the files and copy the .kml file into the content/userdata/poi folder and the .bmp files into the content/userdata/usericon folder and restart the satnav.
Trouble is, I don't have those folders. Under "content" there is no userdata folder. There is a POI folder, which is where I presume the .kml file goes - but there is no "usericon" folder - just these:-
So, any idea where the bmp files go?
Secondly, is there another similar file for German Stellplatz?
Lastly, what's the best way of entering addresses when on the Continent? Use co-ordinates, or are postcodes supported (going to France, Germany & Switzerland)?
I presume the map update issue on these has not been resolved. Mine date from 2013, I doubt too many new roads have gone in since then.
Any help gratefully received!
May 6, 2010
547
638
Doncaster
April 2010
Contact Lunarman he seems to know a lot about these. I think the last map update he did on mine was dated 2015
Dec 11, 2011
839
2,102
Nr Hastings, East Sussex
AutoTrail Tracker RL
since 2010
I think I recall that if the folder isn't present then just create it and put the files in there. The system will then find them there when it starts up.
Feltwell
Aug 27, 2014
1,910
3,928
Shropshire
McLouis Tandy 640+
Since 2014
Thank you! That was so blindingly obvious that I hadn't thought of it - Doh! - works fine now. Have a put a comment on the download page for anyone else who is hard-of-thinking.
So what does everyone use for location input when abroad? Co-ordinates?
I only ever use postcodes in the UK but it seems in some other countries the code can cover quite a large area
rich g
480
855
Worcester
A/S Warwick
since 2013
I always use Co-ordinates when abroad and have never had a problem,i also use a Nozatec.
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
I use google maps then on the satnav use find on map
ianandkath
897
1,519
spain/uk
a class
2 years
cords , as france postcodes are too big, you could be 10kms away.
as someone has said, just create the folder.
i have the truck maps if you need them.
JockandRita
11,462
150,129
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Ditto here too, but I use co-ords in the UK also. Choosing the correct format is easy using the "More" button, at the bottom of the Nozatec screen. It has been far more reliable, than the TT720 with European Truck Maps ever was.
Cheers,
Jock. :)
suavecarve
7,550
38,953
Surrey/Hants
Rollerteam 685
July 09
Co ordinates all the time via the more button with "Miss Wong Wei" as we call her. No matter how hard I try I just cant get rid of the bloody speed and alert warnings even though they are off. I have now resorted to turning the volume off on them as well
