Chemical Toilet Fluid (1 Viewer)
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
Has anyone use Mac a Loo toilet fluid. At less than £2 A litre it semms good vaue and It's Formaldehyde free. Tempted to buy some and see but thought maybe someone knows something about it.
Tony Hunt
214
Wimborne, Dorset
RV A class
No need to have the cost of any toilet fluid if you invested in a SOG. Had mine two years now and works a treat, no fluid costs, no smells, totally green.
andyman
Sep 23, 2007
1,710
1,970
Leicestershire
At the thick end of a £100 it's far more expensive than fluid. I use Thetford fluid and when bought on offer it's £14 for 4 litres which last us about 12 months. Unless I were to switch the sog each time I change M/H based on 3 years ownership fluid £43 sog £95, net loss of £50. It's a no brainer for me. But then I'm just tight.
Andy
Dec 23, 2007
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
Can you get fries with that??:ROFLMAO:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Andy
Make your own SOG for a few quid, easy and cheap and works. Thread on here somewhere
Terry
11,932
9,079
Lincolnshire
Can't remember ;)
made my own sog and put details on here, total cost zero but if you bought all patrs it would cost 3ins comp fan £6 micro switch £4 and a bath overflow £3 and asuming you have some glue about £13 in total
terry
Braunston
1,408
7
Hi,
While on the subject SOG, I don't know if its just my unluck but i have been unfortunate to to have been waiting to empty my Elson cassette behind someone emptying their cassette who had a SOG or that type of item fitted and there was a smell and it left nothing to your imagination, perhaps they weren't using the equipment correctly but i still feel that some sort of additive that masks the smell when emptying is a good ideal ???? or I have i just been unlucky.
We use what ever we can purchase the cheapest that will mask the smell when the toilet is being used and when its being emptied, and that is usually some form of cheap disinfectant or we have used the Bio powder that you are supposed to add to your washing machine to get the stains out, they normally work a treat, it just a matter of trial and error until you find something that masks the smell and is acceptable to you. but I also think it is important to smell reasonable when being emptied.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
A sog prevents noxious smells entering the van, it does nothing to deodorise the crap. If putting up with the smell when empying bothers you wear a perfume impregnated face mask and try to empty when no one else is around. The formaldahide in Blue loo is dangerous to the environment so should be avoided.
Terry
11,932
9,079
Lincolnshire
Can't remember ;)
"formaldahide in Blue" I belive it is no longer allowed to be used and all chemicals for the loo are E/friendly now.S--t stinks so as wildman says wear a mask or hold your breath:ROFLMAO::ROFLMAO:
terry
owlgirl
63
one of the best things we bought (SOG) no nasty niffs in the van now.
we found that the liquid has lost all the nice smell and only worked for a short spell then I used to put more in to try and avoid this happening
American Dream
156
Lincoln
Its a small fan and a venting system for your thetford cassette, not much use to those with American RVs. Basically your waste is broken down naturally without the need for chemicals. The fan comes on when you flush and extracts air out through a carbon filter and thats stops smells coming into the van!
It is German of course and excellent.
COURTESY OF THE 2ESCAPEES.Link Removed
paul&stella
79
I'm so glad someone else asked what a SOG was so I didn't have to show my ignorance!
So on this delicate subject, i have always used bio-degradable cleaning products in my house, can I use these in the motorhome to clean the bathroom generally?
Also, we are just about (tonight!) to buy our first second hand motorhome, and though it is immaculate I did notice that some bits of the white plastic loo fittings were slightly yellow stained, which I'm guessing (hoping) comes from using ordinary household bleach which would make plastic turn yellow after a time. Anyone got any ideas how to turn these plastic bits back to white or would it be a better idea to buy a new loo - how much?
W
Wresting
Stained plastic
Hi,
If the yellow staining is only on the surface, use a metal polish (e.g. Brasso) to get it off. This works on most plastics.
It's also possible to buy pvc solvent cleaner, but you have to be careful with this: wipe across the surface with a cloth dabbed with the stuff - if the liquid stays on, it can soften the plastic and cause wipe marks to be left behind.
Terry
11,932
9,079
Lincolnshire
Can't remember ;)
diy sog
here are some pics of my diy sog, should be self explained
terry
Terry
11,932
9,079
Lincolnshire
Can't remember ;)
and a couple more, The 2 x 2 ins fans were replaced by a single 3 ins one
CARBON FILTER from cooker hood
BATH OVERFLOW X 2
MICRO SWITCH
SLIMLINE FACE FIX ELECTRIC BOX & BLANKING PLATE
3 INS COMPUTER FAN
Fix micro switch so that when blade on loo is opened it turns on the fan,make sure fan isextracting to the outside-blow smoke into loo-:ROFLMAO:
with thanks to Vicadicdoc without his imput I would never had tried this. It was completed almost 2 yrs ago without a problem.
terry
Terry
11,932
9,079
Lincolnshire
Can't remember ;)
Paul & stella a new loo will cost aprox
bench type 300
swivel 350
ISH
Terry
