Checking Tyre pressures (1 Viewer)
Biged
159
70
Nottingham
No longer looking
newbie
Last week we fetched our Motorhome :thumb: Nightmare journey but thats another story.
Since then i have been getting things sorted (getting alarm fitted tomorrow). Last couple of days i have been making an adapter to mount a spare wheel in the garage, thats nearly finished and i'm well pleased with it.
Anyway to get to my question.
The Motorhome is based on a Transit twin rear wheel chassis..... how do you check the Tyre pressures?:Sad:
I can't even see the valves never mind get to them, surely you dont have to take the wheels off to check the pressure :whatthe:
Is there some sort of adapter to bring the valve stems through the wheels to the outside?
alfandM
1,065
1,174
sweden
A
Hi and Happy travels in your MH, to check pressures on your rear twin wheels there should be a longer valve stem from the wheel inside if you can not see one, the inner wheel has beem fitted wrong,valve stem's should be at 12and 6 o clock position's of the two wheels,if you still cannot find them take the MH in to a tyre depot and have them to check it out,Regards Alf.
francour
94
13
Pontefract
a class
since 1990
tyre pressures
you can buy valve exstensions and don't forget nearside wheel nuts on a twin wheeler left hand thread ::bigsmile: Thanks francour
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
You can get the extentions from any Worthwhile Tyre dealer ,AND If you smile nicely at Jim :notworthy: , he'll sell you a set of his tyre pressure monitors, Just a casual glance is all you need then to check your pressures, if your Tyres lose more than 4lp psi the little light in the end flashs:thumb:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
you usually dont need any extensions if you are using a push pull tyre blower upper.
one with an end like this Link Removed
i dont like the extensions . should you get a stone trapped and use a bar to remove it then you risk damaging the extension .
plus if its a rubber version have seen them perish .
there all sorts of extensions . but with the right set up you can manage with out . i do.
Biged
Biged
159
70
Nottingham
No longer looking
newbie
Well i got some extensions which turned out not to be long enough :Doh:
Getting the wheels of the spigot for the first time EVER was 'interesting' anyway with a good thrashing with a rubber mallet and some leverage between the tyre they parted company, it was at this stage that i realised that the 140mm ones i had were just not going to do it :Sad:
Some 210mm ones now on order :thumb:
While i had the wheels off i though best check the pressures to see what i have been driving back from the dealers with (170 miles). Rear wheels should be 50psi, inside wheel 37psi outside 60psi :Eeek:
Well serviced MOT'd and checked over :Angry:
By the way someone replied that the rear nearside are LH thread, only on the early versions now RH the same as the rest.
