Checking RV charger.
Discussion in 'Tech/Mech General' started by Bryan, Oct 25, 2009.
  1. Bryan
    Bryan Read Only Funster
    Jul 19, 2007
    2,096
    342
    Hi,
    In my RV I have a converter/charger model 7355.
    How can I check that the charger bit is working?
    The battery voltage is approx. 12.6 volts and this was after they went COMPLETELY dead whilst off hookup and after connecting the hookup it took a bit of messing to get the convertor back on-line (involving jump leads). The battery voltage was then 11-12v and slowly crept up to 12.6
    What I want to do is connect a meter somewhere to make sure that the charger bit o f the converter is actually outputting as it should.
    Where should I measure and what reading should I get?
    TIA
    Bryan
  2. johnsandywhite
    johnsandywhite Read Only Funster
    Jul 29, 2007
    2,348
    15
    Doncaster/Spain
    :Cool: On my Newmar the Charger actually plugs into a socket in the basement where the line feeds in. If yours is the same? Then disconnect it, measure the voltage, plug it back in and re-check the voltage to see if there is ANY difference? :thumb:
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,364
    18,054
    YO11 2BD
    i wasnt aware power supplies/converters had a seperate charger circuit Bryan.
    as far as i know they are just a fixed voltage power supply...13v + which will charge your battery at that voltage only....you cant get a higher battery voltage than the power supply can provide
    thats why they arent very effective at fully charging your batteries.
    a proper 3 stage charger will output upto 14.4v + to boost charge a flat battery then revert to a conventional charger/power supply to maintain the battery.
    the last stage is a maintainance float charge if no current is drawn from the battery.
    so yours is never going to fully charge the batteries anyway.
  4. Knine
    Knine Read Only Funster
    May 19, 2009
    5
    South West Scotland
    Hi Bryan
    The problem re-starting the system after the battery went very flat is not unusual. The charger sees the low voltage and thinks you might be trying to charge a 6 volt battery (which could be dangerous) so it remains in the off state.
    The fact that once the battery voltage was raised by the jump-start and the charger got going, the charger appears to have raised the battery voltage from 11 volts up to 12.6 volts says that the charger isn't totally dead.
    However, it needs to take the battery up to 13.8 volts to charge it properly.
    You could maybe fit a known good battery to the charger output and see if it sits at 13.8 volts with the charger on (some chargers will not work without a battery fitted - this sounds like one of them). As pappajohn said, 12.6 volts isn't enough to charge your batteries. My guess is that either the charger's current limit circuit is faulty or there is a very loose cable between the charger and the battery or there is a large load on the 12 volt circuit.
    Hope this helps
    Knine
