Check mobile broadband coverage
Discussion in 'Top Tips & Tricks' started by keith, Dec 14, 2010.
  1. keith
    keith Funster
    Aug 25, 2007
    3,301
    1,685
    Ecclefechan
    Thinking of getting a new mobile broadband dongle? This site gives you maps to compare coverage of the major UK providers.
    Quite enlightening to see the comparison between your network & the competition. :thumb:
    I always thought O2 had good coverage (been with them for years) but in comparison they are way behind some of the others. Vodafone not much better. :Eek!:
  2. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,499
    895
    South Glos
    I have an unlocked dongle with both a 3 and a Vodafone sim. I only use it when away in the van and from experience I would say that 3 has the best signal across the country.
    Lunarman
  3. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
  4. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Were did you get it unlocked, I have 3 dongles that I woud like to unlock but there is no one near here that does it.
    Doug...
  5. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,954
    Can't see a link Keith. Is it me or is it missing?
    Graham
  6. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,427
    5,457
    East Sussex 01-580-881288
    Whatever one you get, they all now expire after 30 days even if you have not used up your useage limit.
    I have an older Vodaphone dongle which does not expire for 180 days (no longer available) which works fine at home (Berkshire) and on the boat at Poole but useless at the dealership (Robertsbridge) so I use an O2 dongle there which does expire after 30 days.
    The O2 we use at shows all over the country which seems to work fine but won't work at Poole or at home so buy one of each and use whatever works best wherever you are
    Peter
  7. Jim
    Jim Ringleader
    Jul 19, 2007
    26,998
    79,483
    Sutton on Sea
    Keith, how about a link to that map:Smile: ta:BigGrin:
  8. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    9,064
    14,369
    Norfolk
    I find the 3 dongle beats vodafone, O2 and BT for signal strength and speed.
  9. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    I have a 3.co dongle and a Vodafone Dongle, a t-mobile mobile and I find all 3 of these companies over state the level of there coverage.
    If you are in anything other perfect reception then there maps are not accurate.
    Doug...
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,368
    18,055
    YO11 2BD
    i'll jump the gun and say it could be this one....UK COVERAGE
  11. keith
    keith Funster
    Aug 25, 2007
    3,301
    1,685
    Ecclefechan
    Oh bugger, done it again. Here it is: :Doh:
    Broadband coverage
    Different one John but looks like the same info.
    Edit: Sorry folks been out all day so a delay in correcting my mistake. :Doh:
  12. gozomike
    gozomike Funster Life Member Life Member
    Mar 16, 2010
    887
    667
    Warwickshire - sometimes - but not often
    I have been using a 3 MiFi dongle for a few months now, it works fine.
    If the signal is marginal it can be helped by raising it a few metres on a flag pole to lift it clear of any local obstructions. As it does not need to be wired to the computer (phone signal in and Wifi to the computer) there is no problem doing this. :thumb:
  13. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    I am confused as to what dongle that you have, do I understand it right, you have something that you can mount on a pole that receives a 3.co signal and then retransmits the signal on WiFi?
    Doug...
  14. GJH
    Aug 20, 2007
    27,349
    34,954
  15. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    Unfortunately its not what I was hoping for, my house is in a poor reception area and I was looking for a external unit that did not run on batteries, that way I could place it 2 or 3 meters above the house to improve the reception. At the moment I am working on the idea of making a normal dongle water prove and running it on a PoUSB cable.
    Doug...
  16. gozomike
    Mar 16, 2010
    887
    667
    Sorry for the delay in responding, I have been out & just returned.
    Yes that is the unit and whilst it does have a battery in it that is charged via a USB connection so you could do what you are saying with it. Running it at home (when in the UK) I have the USB plugged into a powered USB hub for power. If in the mobile home with it inside I plug it into my laptop 12volt Power Supply unit which has a USB power output, alternatively I can plug it directly into the laptop. I only run it on the battery when it is up the pole to save running a lead to it. So you could just run a USB lead up to the unit for power, the signal would just be sent down by Wifi.
    Obviously I do not know how the signal from 3 is at your location so cannot say if the signal would then be good enough.
  17. Ruddy
    Ruddy Read Only Funster
    Feb 24, 2009
    99
    Haverhill,Suffolk
    Peter,
    Your quite right that the old ones dont exipre, But they dont expire after 180 days :thumb:
    As long as you log on to the net work at least once in every 180 days the usage will never expire.
    I took mine into a Vodafone shop to have the content control removed (I couldnt even type Essex into google because it had "sex" in the word :Rofl1:)
    And the bloke wanted to update it to the lastest software....I told him if he did then vodaphone would be paying for the dongle until I bin it.
    Ive had it for 18 months now and im still using the £15 it came with :Blush:
    ps dont forget to turn off atomatic updates in the settings.
