Cheapest route to cool air ? (1 Viewer)
Jul 27, 2011
145
197
Kilmun, Dunoon
Knaus Sport TI
Since 2012
Hi....
I have been looking into all the options for a small aircon unit after enduring a few sleepless nights down here on the Costa Del Sol during summer.
Looking at the prices circa. £1500 upwards I starting looking at alternative options.
We do a lot of wild camping so 240volt is not readily available for the power requirements of even the smallest portable units. e.g 2.5Kw
I then started looking at those evaporator units which is a pseudo aircon where you fill a container with water or ice cubes. You get can get 12 volt versions from the US of A. Even the largest units only draw 100 watt at 240 volt. My line of thinking was to run one of these off a true sine wave inverter due to the inductive load for the fan motor connected to a 100Ah battery. The air cooler (aircon) costs around 135 to 165 UKP with the true sine wave inverter coming in at circa 200 UKP. Some of the specs quote very tongue in cheek at 30% reduction in temperature with a room 9 sq,M.
Any thoughts or experience ?
atb Neil
43,286
49,221
100watts via an inverter will draw 8.3amps per hour so the best you could expect from a 100ah battery would be around 6hrs continuous running.
inverters are around 90% efficient, 100% in, 90% usable power out, 10% wasted energy as heat. so it would be closer to 4.5hrs running.
you should never discharge a battery below 50% capacity or it may be damaged
BwB
917
1,170
Suffolk UK
Resting b'twix vans
Since 1990
Best if you have very low humidity so don't work great in the UK but might be ok if you have less than 50% where you are going to use it. There were some kits available for truckers and there were lots fitted but are being replaced with something which works. In best case internal air temp only drops 5c from ambient.
Apr 27, 2008
11,837
14,056
Eastbourne East Sussex
Hymer low profile
Since 1972
We've had some pretty hot nights (the weather I mean) and have always kept pretty cool with a thermostatically operated fan in the roof vent over the bed. Bought from Johns Cross and one of the most useful bits I've ever bought. Uses 0.3A-3A dependent on speed, we found near to lowest is best and is quiet, whereas top speed is too noisy if you want to sleep.
http://www.johnscross.co.uk/products/fiamma-turbo-vent-with-polar-control.html
Spacerunner
607
197
Hampshire
I second the roof fan.
Our moho came with a Fiamma turbo vent factory fitted over the bed.
Its reversible and doubles as an extractor fan when cooking. Its variable speed and at reasonable revs is fairly quiet.
In really hot weather just peel back the bedclothes and let the fan keep you comfortably cool.
I'm not a great fan (no pun intended!) of air conditioning as it prevents you from acclimatising to current conditions.
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
Fantastic Vent
Look at Fantastic Vent .. it is on a lot of American motor homes and fits in to the normal size roof vent... I know a few UK dealers sell them.
They are 12v and drawn air from outside via an open window through and up and out.. two speed motor.. very quite and boy do they work... only about £150 isn if I remember.
We often use it in the day time instead of the aircon.. they say to open a window on the side where the vehicle has shade to get the best results.
Bob
Neil n Pat
Jul 27, 2011
145
197
Kilmun, Dunoon
Knaus Sport TI
Since 2012
Re cheapest route to cool air
Thanks for all the feedback.....the main problem down here during the summer the ambient temperature can get to 37 in the shade which doesn't diminish much during the evening. It really isn't to do with becoming climatised having lived here since 2006. You just cannot sleep in the lower thirties. I have tried fans... the only problem is you are just circulating hot air. The motorhome becomes almost unbreathable during the night even with all the windows open. Walking the paseo maritimo in San Pedro at three in the morning makes one focus on this issue :cry:
Taking onboard all the suggestions whilst also noting the cost of an installed dedicated aircon at 1.5k plus plus how about this idea.
What is the smallest portable aircon you can buy ? how many cube can it cool and what power requirement. If I can find one that can run off 1.5Kw I would investigate getting a Honda (silent'ish) 2Kw generator. Going this way I can kill two birds with one stone... have a cool motorhome and the benefit of the generator for other uses.
atb Neil
slobadoberbob
6,151
1,960
25 years & counting
we have a 4 kw
atb Neil
On the RV they fit a 4 kw generator to power the aircon... it needs around 2 kw for running and a bit more at start up.
I have a free floor standing one at home and they and noisy plus to get an air con to work you need to have everything closed up.. i.e no vents or windows open. The air con works on the windbag just fine, but the fantastic vent drags air trough.. but if you have that heat then I doubt it would be much use. We have used it in the South of France but it was about 30 degree there.
Bob
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
TestimonialsHow it worksContact UsSpecificationsHome
Mobile air conditioning for motorhomes and caravans
When camping during the hotter months high humidity and high temperature can
lead to discomfort and sleepless nights in motorhomes, caravans and campers.
We offer a cost effective and quick method by which you can cool your camper.
If you use your touring caravan or motorhome during the summer, or if you travel to Europe you're bound to have dreamt of having an air conditioning unit in your home from home.
But let's face it roof mounted a/c units can cost £1,000 or more, need specialist installation, weigh a tonne and there's a good chance that you will lose most of the investment you have made when you sell your van on.
Well you'll jump at the chance of having this unit because there are no installation costs - it is completely portable and hangs on your van window. It is easy to install and easy to use.
This is a proper refrigerant split pack unit with external condenser unit and internal fan unit that provides user controls. It’s not a water cooler or a thermoelectric cooler. It produces 700 watts of cooling (2,400 Btuh) but only uses 350 watts – that's 1.52 amps so won't trip those 5 amp or 6 amp hook-ups!
A portable a/c unit can be moved to balance the load in your tourer caravan making it easier to get the maximum nose weight.
A portable a/c unit can be left at home (if it's not going to be needed) thereby reducing your towing weight or improving fuel efficiency on motorhomes.
A portable a/c unit can be used elsewhere while you are not using your van. Just think of a surface where it can sit or a window it could hang on meaning it is possible to use the air conditioning unit in boats, cabin cruisers, static caravans and even tents.
Be sure to buy one quickly as these sell out every single year despite a selling price in Europe of up to 700 Euros!
Our Price is £450.00 plus £14.99 for courier delivery to most UK mainland postcodes.
Benefits
Easy to fit and remove
Transferrable between vehicles
Small and quiet cooling
Advanced split pack design
Simply plug in and chill out
£450.00 inc VAT
Now in stock!!!
Order Now!
Portable air conditioning unit designed for motorhomes & caravans ...
www.coolmycamper.com/
Want a portable air conditioning unit for your motorhome or caravan? Our mobile air con unit hangs on the window frame and cools your 'van to a comfortable ...
Would this be any good?
