Chausson Welcome 76 Tall Garage Hinges Problem (1 Viewer)
Jerry TLD North Yorks
3
Thornton Le Dale
Chausson Welcome 76
since 2002
Wondered if any of you have come across tall garage door hinges problem
on Chausson Welcome 76? Ours have gone solid after a valeting and now difficult to open door, difficult to spray in WD40, tried to remove hinges from frame find they are bonded!! Chausson want £320 plus vat and carriage to send new door frame with hinges, EXTORTIONATE!!! Any Ides?
Jerry
tonka
10,824
21,514
Cannock, Staffs
A class Burstner 800
Since 2000
I have just re-read a post on the Autotrail facebook group.. Almost similar problem to what you are having,.
Unfortunately no real answer except.. DONT USE OIL as it makes it worse.
An "Autotrail trained" person has stated about taking them apart and re-drilling !!
" We separate the hinges and drill out the hole . Usually a 5.5 MM drill bit is perfect"..
SandraL
1,373
985
Somerset
Hymer b694sl
Are they "standard" external hinges with a vertical pin? If so there is a small plastic cap covering the top and bottom of the hinge where pivot pin is. These caps can be prized off with a knife or screwdriver and oil fed in, easier on the top as gravity assists. On a door hinge I once found alloy hinge had corroded onto the steel pin, only way I could free it was to apply heat using a gas blow torch, this is likely to lead to some discolouring.
lorger
9,655
90,485
Dumfries
Knaus Sun 650MEG
I had the same issue with my last van, I took the doors off and stuck a drill in the hinges to clean it out worked a treat.
J
3
Thornton Le Dale
Chausson Welcome 76
since 2002
Jerry
NOTE The hinges are BONDED to the door frame so cannot take the hinges off.. Will try taking the top cap off and use paraffin to penetrate and free the pin.
