Chausson Solar Panel Connection
Discussion in 'Solar Power' started by ppsontour, Jul 11, 2015.
  1. ppsontour
    ppsontour
    Jan 17, 2011
    9
    north kent
    I have a Chausson suite garage 2011 that i want to fit a solar panel to. I believe there is a pre-wired connection in there somewhere. Does anyone know where i can find it or even what it looks like ?
  2. andy63
    andy63 Funster
    Jan 19, 2014
    2,227
    8,542
    south shields
    Hi. Your van will most probably have a main box where your 12v and 240v fuses and breakers are located...incorporating a battery charger etc something like a Sargent control unit... The later ones I believe also have a solar charge controller built in,so if you can locate that and post the model someone will be able to help..
    Ta Andy. .
  3. andy63
    andy63 Funster
    Jan 19, 2014
    2,227
    8,542
    south shields
    A bump... sure someone will be able to be more helpful.
  4. Puddleduck
    Puddleduck Funster
    Jan 15, 2014
    6,713
    14,450
    Scottish Borders
    If you have a Chausson dealer or workshop nearby they might be able to point you in the right direction?
  5. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,690
    3,212
    East london
    Our chausson also has a connection for solar. Its all in the manuals and circuit diagrams that came with the van.
    I can go check... But not tonight
    • Like it Like it x 1
  6. bungy
    bungy Funster
    Jan 24, 2010
    2,250
    4,142
    Welsh marches
    In our welcome 85 its behind a panel in a cupboard above the kitchen area...wouldnt have known itvwas there if i hadnt found it whilst browsing around the circuit diagram for the van!!!
  7. ppsontour
    ppsontour
    Jan 17, 2011
    9
    north kent
    The problem is that I have not got the wiring diagram.... I have emailed chausson and they have not replied and the guy at the dealers does not know where it is. He said just connect it directly onto the battery but I would rather wire it into the pre wired connection. If I can find it.....
  8. andy63
    andy63 Funster
    Jan 19, 2014
    2,227
    8,542
    south shields
    Duplicate sorry
  9. The Wino
    The Wino Funster
    Mar 23, 2012
    1,214
    2,254
    leicester
    Found ours last weekend I think!!. It is in the cupboard over the sink there is a false side to the cupboard one side (the outside ) has the tv ariel and 12v socket the inside another 12v socket. If you remove the inside panel (4 screws) there is a connector with 2 wires not connected which I think are the solar panel wires. The wiring diagram suggests this. I do not know however if there is a solar regulator I seen to recall there is one capable of taking up to an 80w panel does anyone know better?
