Charging vehicle battery from solar panel (1 Viewer)
buyer
Funster - Life Member
218
74
leicestershire
american coach
20 plus another 12years tugging/small campers
I fitted a solar panel last September and it is working fine,as I went into the camper today and the leisure batteries where reading 13.8 volts (it has been parked since November without electric hook up. But my vehicle battery is dead flat, I haven't checked for a drain yet,I will do when I get some time. I know there is a simple bit of kit that you can connect to the leisure battery bank and the vehicle battery that charges the leisure batts first then dumps exces charge into the vehicle batts,but I haven't got a clue what it's called or where to get one from or how much I should expect to pay for such an item ,I would be gratefull if someone out there would let me know,as I want it fully working for the end of march.thanks in anticipation. Steve.:thumb:
buyer
buyer
218
74
leicestershire
american coach
Thanks for the link, that looks like it will do exactly what I want :thumb:
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
I have a VanBitz Battery Master and it works.............perfectly.
Recommended.....:thumb:
43,295
49,271
if your engine battery has been stood since November there's a very good chance it is knackered.
lead acid batteries wont tolerate being left in a totally discharged state and rarely recover
it will charge but only a surface charge and will have no capacity so will die in seconds/minutes once a load is applied.
Sep 27, 2007
837
289
Shropshire based
Globecar
started in 2001
another option
1) Solar Wind Split Charge Leisure & Engine Battery Camper available from "Renewable Energy" when they have a stock replacement, this one passes all excess to the engine battery once the leisure batteries reach 13.6 volts.
2) Duo-battery charging solar controller, this unit allows you to set the charging in 10% units from 90% leisure 10% engine ...to 90% engine 10% leisure battery. Available from Sunstore at www.sunstore.co.uk .
I have had the same problem as you, item 1) is currently out of stock, item 2) looks like the unit I will be purchasing, list price £27.00. The thought of being able to select say 50-50 charge when in store is very attractive.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
This is what you describe but a battery master will give your engine battery a top up if it needs it from your leisure battery regardless of whether there is any solar input.
Link Removed
Grandad Pete
Chelmsford
Coach built
Battery Master
Hi Steve, I think what you are looking for is the Battery Master. I had one fitted when I had an alarm fitted. It works fine, it trickles the power across from the leisure to the vehicle battery. I got mine from www.vanbitz.com and I think it cost about £70. Their website has all the info and they are very helpful on the phone. I hope this helps. Regards Peter.:thumb:
Destination Unknown
398
835
Anywhere and everywhere
American A Class
Not Long Enough...!!
We have a couple of this type of relay fitted, once the leisure batterys are charged via solar/lecci then the relay then splits the charge to the chassis or spare leisure battery.
Had no problems with these and at a low cost.
Link Removed
Jan 28, 2008
10,111
18,365
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
if you have a split charge relay system you can just link the two terminals using a short length of wire with a low ampage fuse in it, this will allow your solar to feed both batteries the fuse will blow if you try to start the van with the link in place protecting the leisure side from high loads
cost would be under a fiver
