charging up
Discussion in 'The Beginner' started by stevew451, Sep 26, 2009.
  1. stevew451
    stevew451 Read Only Funster
    Sep 19, 2009
    18
    county durham
    having just purchased the MH need to charge the leisure batt hooked up onto wall socket nothing no lights no power to fridge what could be wrong
  2. johnsandywhite
    johnsandywhite Read Only Funster
    Jul 29, 2007
    2,348
    15
    Doncaster/Spain
    :Smile: Hi Steve. There should be a switch somewhere with a meter. You should be able to switch middle/up/down. Middle for off, Down for House battery and Up for Motor battery. The House and Motor batteries could be the other way round. No lights? Switch will MOST likely be in the middle (OFF) position. :thumb:
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,112
    17,779
    YO11 2BD
    hi steve and welcome.
    johns right about the panel switch BUT as you have no power at all then find the 230v mains fuse box, the one with the circuit breakers in, and check the main switch is turned on.
    if it is you will need a multi meter to check volts at different locations along the way.
  4. stevew451
    Sep 19, 2009
    18
    county durham
    there is no middle setting just leisure and car mains fuse system are all on not in trip position
  5. pappajohn
    Aug 26, 2007
    30,112
    17,779
    YO11 2BD
    is the charger turned on?
    there should be a switch somewhere on the charger.
    if the battery is fully discharged you wont have any 12v if the chargers off.
    if the battery is fully discharged its more than likely knackered anyway.
    that wont affect the fridge 230v operation though.
    have you checked there is power at the vans mains fuse box.
    could be a break in the hookup lead.
    simply press the main switch trip test button...if it trips theres power there.
  6. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,164
    14,018
    Heavan
    mine is fused as well in the main fuse box. Have a check of you fuses.
  7. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    :thumb:Hi Steve
    I had a blown fuse on the leisure battery it was a 20amp worth a quick look as I had nothing working. Pete and welcome to the site there will be an answer on here somewhere:thumb:
  8. stevew451
    Sep 19, 2009
    18
    county durham
    thanks every one sure there is an easy answer to this have a mate who worked for elddis will see him first let you know how i get on have fun
  9. davejen
    davejen Funster
    Aug 21, 2008
    1,262
    718
    Kirkpatrick Fleming Dumfries
    Hi, Steve welcome to the site. Are you sure the 240 supply is on? Just a thought!
    Cheers, Dave:thumb:
  10. stevew451
    Sep 19, 2009
    18
    county durham
    hi will try putting the 3 pin 10 amp adaptor onto the MH socket first to see if hook up lead is shot the 240 trip switch did pop when i pressed the trip button so check the battery out as well
  11. stevew451
    Sep 19, 2009
    18
    county durham
    May have discovered the problem the zig unit is an old CP V3 which may not have an internal charger vus will only charge when running and not on hook up is this true ??
  12. haganap
    Dec 5, 2007
    11,164
    14,018
    Heavan
    Well that would be a bit strange and something I have not come accross before. Why though would you have no power in the van if this was the case? surely it would be running straight off the mains?
  13. stevew451
    Sep 19, 2009
    18
    county durham
    checked with zig it has no charger will get checked out by sparky loks like an upgrade is on tghe way so which zig unit ??
