I use one of these ....However, an inverter can also be useful for other jobs, like running the hand held electric mixer for whisking Angel Delights etc.
JJ
Does that produce 19vdc....or is it simply a 12vdc charge lead.Just buy a 12v lead for you HP, here's the one I got off EBay. Forgot to say search for car charger.
Yes it produces 19v, over the years I've had one for every laptop I've ownedDoes that produce 19vdc....or is it simply a 12vdc charge lead.
And running water too?Well jolly good for you...
I used to use one of those too, in the old days...
...but then they brought electricity into our village.
JJ
No need to use 220 volt AC mains.
Your laptop runs on DC, the exact voltage will be on the unit, and also on the plug-in mains transformer that it came with.
We also just use a 12 volt step-up dc charger...it's a sort of universal one which has a little slot which allows you to change the output voltage to 14, 16, 18. 20 volts etc...our laptop is nominally 19 volts DC so we set the charger/transformer to 18 volts, stick it's ciggie lighter plug socket into any 12 volt socket in the MK, and it charges perfectly.
It came with about 8 different little plugs to plug into various electrical things, eg laptop, bluetooth speaker, camera, etc.
Maplins etc, or ebay.......
Your 600 inverter is perfectly capable of the task, however, there is the inefficiency of taking the power from 12v to 240v and then back down to 19v. That said a laptop charger uses roughly 2 thirds of toss all power, so not a huge issue a 2x100ah bank is pretty good, you will hardly draw anything from that.I am taking my HP laptop with me abroard this summer and as my van is all 12v with 2x 110 a VB "s.Will I be able to charge straight from van or is the 600 inverter I have suitable ?
Hardwork charging a lap top with that.
True but a DC to DC converter will have less losses than the inverter route and a lot neater solution.A step up device is not as simple as just using 12 volts. The 12 volt DC is converted to AC then transformed to the necessary voltage then rectified to DC. There must be some losses somewhere along the line. The experts on here will either shoot me down in flames or agree with me.
Dave
