Charging Info (1 Viewer)
pvw10
273
45
Gloucester
Coach built
since 2011 after tugging.
Howdy campers.
Seems so daft to me that when plugging into mains it doesnt charge the engine battery, before i get my tame spark round anybody found a sound and simple way to do this ?
tonka
10,796
21,440
Cannock, Staffs
A class Burstner 800
Since 2000
You can install a "B2B" charger...
I dont know much about them but others will soon be on and give you the info..
OR Buy a new Apache 700 at £53,000 and they charge both batteries..:ROFLMAO::ROFLMAO:
Link Removed
Terry
11,904
8,969
Lincolnshire
Can't remember ;)
or simply buy a 3 way charger from aldi (£12) and remember to plug it in ::bigsmile:
terry
g8ysn
638
417
ng219ep
coachbuilt
g8ysn
bought tirckle charger from halfords [forgot price] never suffered flat battery since bought it 3 yrs ago now also have one fitted to spare 120amp battery for wife,s nippy machine, plug in mains or genny, red licht shows when discharging green when charged / simple he:Doh:
43,207
48,802
not cheap but reliable and fit & forget.
http://www.vanbitz.com/product/battery-master/
cheapest option is a length of wire capable of 25amps and a couple of fuses.
run the wire between pos terminal of leisure and engine batteries with the 25a fuse in an accessible position close to one battery....fit the second fuse at the other battery.
leisure battery must also be earthed to the chassis though or it wont work...unless you run a separate earth wire between batteries as well.
BEFORE starting the engine you MUST pull ONE of the fuses or they will both blow
pvw10
pvw10
273
45
Gloucester
Coach built
Link Removed
Love it, nice one.
Apr 27, 2008
11,793
13,949
Eastbourne East Sussex
Hymer low profile
Since 1972
Or you could fit a switch to save fiddling about pulling the fuse, which are difficult to grip (or have I just got fat fingers)
pvw10
pvw10
273
45
Gloucester
Coach built
I like the Vanbitz hobby, i will explore further thanks
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
PappaJohn's suggestion with a £12 split charge relay fitted in the middle is what I use to keep my cab battery topped up from the leisure battery. Works on solar and mains.
My relay is set to prioritise the leisure battery and stops the cab battery from draining it.
10,104
18,259
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
if you know where the split charge relay is and its accesable you can just link across that with a fused link or fuse and switch if its more remote might be easier than linking batteries
actually the best would be a trip which would blow if you try and start the van that can be reset much like most house fuses now
oldun
747
162
St Neots
VW Campervan
Since 2001
In my van I can charge either battery from the ehu via a switch on the distribution box.
I can also trickle charge the engine battery via the habitation battery using a battery to battery (b2b) box.
pvw10
pvw10
273
45
Gloucester
Coach built
Thats the way it should be, all makers note.
Daveo2006
1,164
998
kent
Apache 700
3 years
when my leisure batteries are charged it auto switches to charge vehicle battery or i can switch manually via 12v control panel.
pvw10
pvw10
273
45
Gloucester
Coach built
Thanks for this tip, for peace of mind plus the superb help of the seller i bought one and will fit it very soon.
pvw10
pvw10
273
45
Gloucester
Coach built
cant go far wrong with a battery master....simple operation and a fit & forget item
Well fella cheers, he she is installed and working, soooooper item (pls note this is BEFORE i tidied up).
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
No, No, No!
Before anyone else gets confused, a Sterling Battery to Battery charger is NOT designed for maintaining your starter battery when on EHU!
It is an adavanced alternative for charging your habitation (leisure) battery whilst your engine is running!:thumb:
pvw10
pvw10
273
45
Gloucester
Coach built
No, No, No!
On the factory fit charger yes, i am talking about the little gadget.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
A Sterling chager could be used, but it is not the intended purpose of the device.
If you wanted to spend £350 for one rather than a £60 Vanbitz battery master, then feel free. You'll be wasting the capabilities of the Sterling unit which are better charging of your leisure battery, reduced charging times, reduced engine run times and dispensing with the need to carry a genny.
pvw10
pvw10
273
45
Gloucester
Coach built
You have lost me here !
I purely want to keep the engine battery charged when running on mains, hence the gadget its that simple.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
I'm fairly certain that an Autotrail of your vintage has the facility to charge either engine or leisure batteries by simply pressing the button on the control panel above the habitation door. I know it doesn't charge both simultaneously ad its not an automatic switchover but you can select which battery receives the charge from the mains charger.
D.
pvw10
pvw10
273
45
Gloucester
Coach built
D.
Thanks Dave, that would be great and your right some do but sadly not mine.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Your problems are solved judging by your pic!:thumb:
There seemed to be a train of thought on this thread saying you should have fitted a Sterling Battery to Battery charger. This is meant for a different purpose, ie the charging of your leisure battery with the engine running.
I just wanted to point that out to avoid even more confusion!:Doh:
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Are you sure? On the control panel above the door there is a button with a symbol of two batteries on it, this button selects the battery that receives the mains charge. I assume you have the Sargent PSU2007/EC200 control panel combination. The EC200 control panel is usually sited above the hab door. On the control panel the second button from the left on the top row is the battery select button and this will select which battery is used and also which battery is charged when mains is connected and charger switched on.
D.
pvw10
pvw10
273
45
Gloucester
Coach built
Are you sure? On the control panel above the door there is a button with a symbol of two batteries on it, this button selects the battery that receives the manis charge.
D.
Hi Dave, just checked have one "battery on" which turns the 12v supply on and the other is "battery level".
No others with any battery matter.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Which control panel do you have? Can you post a picture of it please? I only ask out of interest as your details say you have an Autotrail and from your avatar which I assume is your motorhome it would appear to date from mid 2000s, probably around 2004 to 2006 I'd say and this should have the Sargent PSU2007/EC200 combination.
D.
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
Hi Dave the control pannel on my 2004 Apache looks like this ........
pvw10
pvw10
273
45
Gloucester
Coach built
D.
Here you go fella
