treeman
Currently charge LB through Zig CF8 on mains and through alternator when on the move. About to add a permanent solar panel to the roof and now wondering how best to connect up to LB? I've got a 30amp charge controller connected up to panel.
Options I'm pondering are:
1. Connect controller battery output up to LB input terminals in back of Zig (easy to do but not sure if this is ok?)
2. Connect cable from panel on roof to controller in cab then out to LB under bonnet?
3. Other?
Both options would include in-line fuse and some sort of switch to disconnect when not needed or on mains/alternator charge.
Would also be desirable if there was some way of charging vehicle battery should that get low on long wild stays - not sure how easy that would be to accommodate.
Any thoughts?
3. Other?
Any thoughts?
