Charging from elec hookup (1 Viewer)
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
How long should it take for both leisure battery and van battery to both reach full? I have had elec hook up plugged in 5 days and neither batteries are showing full. I do notice however the charger has a red light on but looks like the element is also red...Is this normal?
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Some chargers need switching on ie rocker switch in middle off rt say engine batt left /LB -don't know if yours is like that but your charger should have charged one of the batts in around 24 hrs easy - a small 4 amp hr batt will stick in aprox 80 ish amps in 20 hrs --chances are your van will have something larger than 12 amps per hr charger --check for switches if ok check batteries :winky:
terry
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
What's the element ? Never seen one on a battery charger.
movan
21,492
120,753
Moving around
Burstner
since07
omg. The more I read all these technical threads the more confused I get ... now I have to check a windy coil!!!! Am gonna sell the van after all and get a push bike with a bag big enough for a one man tent.:Sad:
movan
21,492
120,753
Moving around
Burstner
since07
Maybe a photo would help?
Of course ... oops sorry, you meant of the windy coil battery!!!!:winky::winky:::bigsmile:
biggsy
25
10
Hull
Since 2012
Hi, I'm also a Chausson owner, so I think I recognise the red button. It's there to show you that the mains is connected and also acts as an on-off button for the charger. If it's red, it's working. I wonder what charge you are expecting on your batteries? When we have ours plugged into the mains, the control panel shows 13.7 volts on the hab battery. When disconnected to the mains, this falls to 12.6 volts. What is yours reading?
Mike
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Mike
Holding 90% charged then = new batts next yr ::bigsmile::Smile:
terry
irnbru
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Hi all thx for your help, I don't know what the battery reads but the hook up has been on for over a week and neither the cab or hab battery is showing full, nor have they moved any dots. I have a volt meter but unsure which setting it should be on as theres that many.
Attached is a picture of the red coil behind the button. Im wondering if its like a convector heater that glows red when faulty?
Does the picture look normal?
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Hi set your meter to 20v then test and note reading -turn off charger unit and leave overnight then test battery again and note reading --anything below 12.2v and it's a new battery
link to good value battery if it fits size wise Broken Link Removed
terry
714
1,817
Nr Whitby
van conversion
On & off since late70s
Bump
Probably being over cautious but am struggling to think of why a charger would have a glowing coil.
Basically it is a transformer that converts 240v to 12v and converts it to DC.
It is possible that the glow is the charger overheating.
Any electricians out there?
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
it will be the red light to say it's on :Smile:try turning the charger off /see if it goes out :thumb: then back on and see if it glows red again :Smile:
terry
irnbru
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Bump
Am thinking the same but will try Terrys suggestion, but I know nothings changed in last 8 days.
movan
21,492
120,753
Moving around
Burstner
since07
terry
:Doh:Oh yeah.... heard that one before ... usually from over a telephone and spoken with an indian accent........:Cool:
biggsy
25
10
Hull
Since 2012
Still think it's the on/off button for the mains supply. I think the "coil" stuff is simply the light cast from the back of the button.
How do you know batteries are not charged if you have not been able to test them? Does your control panel not give you a reading?
Mike
irnbru
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
The level of dots showing charge is not increasing in either hab or cab.
43,319
49,389
buy a five quid multimeter and check the battery voltage.
only two wires to connect....red one to battery pos, black one to battery neg....in fact, a digital meter should work either way round, before connecting set selector switch to DC volts and thats it.
13.7v and upwards....charging
12.6v and downwards....not charging
simple, reliable and effective.
11,842
14,071
Hymer low profile
Since 1972
In my experience the voltage reading on some of the control panels is not particularly accurate. Echo advice above, get a digital voltmeter, I think I've even seen them in Tesco.
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
That's what my new Indian friend told me over the phone :Doh:::bigsmile:
Just going off my own charger that has a red light to tell you it's on :winky:
terry
phodetheus
248
237
Full timer
Coach Built
3 months
I always say that if you switch something on and a light comes on you can be sure of 2 things. 1. There is power to the bulb and 2. The bulb is not faulty. Beyond that nothing is certain and cannot be taken for granted.
Now I have finished being unhelpful I will try and be a little helpful.
When I managed to drain both my leisure batters it took less that a day on hook up to fully charge them. I would say if they have not charged after 5 days there is a problem with your charging system OR depending on the battery type you may have killed your batteries. Apparently some types of battery if you completely drain them they will never hold a full charge again. (Hope this is not the case for you)
biggsy
25
10
Hull
Since 2012
Ah, OK. Different to ours, which gives some numbers. Looks like an appointment with a multimeter to be looked forward to!
Mike
