treeman
I installed a 214w solar panel last winter in a bit of a rush before a ski trip but now it's time to wire it properly. I connected the panel to a suitable solar controller with standard cable but put in a Tamiya connector between so I could unplug the panel easily from the controller. I connected the battery output to the back of the Zig CF8 on the battery input terminals as it was 6 inches away from solar controller. I again used a plug connector in between so I could switch cables between LB and vehicle battery so I could manually switch between which battery was charged (I would unplug solar panel first as I understand connecting the panel without battery being connected might blow controller).
I plan on running something like 25amp cable direct to LB and vehicle battery now to bypass Zig CF8. My question is what is the best way to manage the desire to charge the 2 batteries at different times?
I'm happy to manually switch myself as 95% of time I want LB charged but now and again it's good to top up vehicle battery so is it practical to install an inline switch on the cables from controller to batteries? would the fraction of time the switch takes likely to cause panel to blow controller or do I not need to unplug panel during switch? What is a suitable switch product?
Or is there a (cheap) device that can manage the power needs between the 2 batteries?
