Charger question
Discussion in 'Tech/Mech General' started by Tony Santara, Nov 16, 2008.
  1. Tony Santara
    Tony Santara Funster
    Jul 26, 2007
    1,494
    114
    Cheshire (ex Mancunian)
    Heres a question for the "Techies"
    My Santara has 50 amp electrics but it seems that on 16 amp hook up the charger won't charge the leisure batteries.:Sad:
    It works fine on main engine and works fine on genny
    I'm told it's something to do with Megahertz , has anybody experienced this problem
  2. stagman
    stagman Deleted User
    Hi Tony,how long have you had the van.How old is the van .Is it manual changeover from mains charger to cab charger or is it automatic.Is there a blown fuse on the mains side or is there an MCB triped.Sorry Just a few questions to start:thumb:
  3. scotjimland
    Jul 25, 2007
    28,976
    25,674
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,923
    YO11 2BD
    hi tony,
    if its the original charger, that may be the problem.........uk leky is 50hz....us leky is 60hz. not sure if it would affect your charger though.
    your usa built genny may be chucking out 60hz so it will run the charger ok.
    engine alternator will bypass the charger anyway and feed the batteries direct.
    have a look <<here>>
    john.
  5. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
    My transformer hummed and finally stopped charging and had to upgrade to a UK spec one via Linda.
  6. olley
    olley Funster
    Jul 29, 2007
    3,859
    2,446
    Ipswich
    Hi I had to change the charger on the winnie, just didn't work right, got a 50amp prodigital from sterling, not a cheap solution but its solved the problem.
    Not sure the Hz is anything to do with it, as its the ratio between the primary and secondary windings which determine the voltage output of the charger transformer, and this is obviously set when its built. But maybe some of the associated electronics don't like it.
    Modern ones like the sterling and I believe the Phoenix, work over a wide range of Hz.
    Just a thought tony is anything else not working on EHU? aircons, heaters?
    Olley
  7. Tony Santara
    Jul 26, 2007
    1,494
    114
    Hi Olley
    everythings working ok on hookup , just not charging the house batteries
  8. Road Runner
    Jul 26, 2007
    14,196
    1,459
    Europe
    A silly question but have you got a 240 volt circuit breaker point hidden away (a house style one) this happened to me and just remembered it:RollEyes:
    I know most 240 volt things are working.
    Just a trip switch on off, would be worth a thorough search Tony, might well be nothing:Wink:
  9. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,841
    6,095
    Mansfield,Notts
    Your not running a huge telly by any chance Tony, probably nothing left for the batteries:Rofl1::Rofl1::Rofl1:
    you might as well just hand it over mate, you just know its going to be the cause of every fault you get:Doh:
    Geo
  10. ruffingitsmoothly
    ruffingitsmoothly Read Only Funster
    Jan 2, 2008
    1,395
    69
    West of Southampton edge
    A silly question but are you sure you are getting a 110/120 volt feed to the mains charger when on hookup?
    I don't think that the Hz would be a problem just maybe cause a humming noise, as asked earlier how does the mains charger get it's feed is there an automatic change over trip from the generator or do you have to change a switch or plug manually?
    Regards Pat
  11. pappajohn
    Aug 26, 2007
    30,252
    17,923
    YO11 2BD
    hi pat,
    an exert from my link........
    Larger motors or transformers are only made for a specific amount of Hertz, so either 50 or 60[​IMG]
    What happens if you connect a 60 Hertz motor to a 50 Hertz mains:
    The motor turns 17% slower
    The internal current goes up by 17%
    The power (watt) goes down with 17 %
    Please note that the same problem also exist in transformers as I explained, they also burn out after a while, also a transformer is made for either 50 or 60 Hertz.
  12. Tony Santara
    Jul 26, 2007
    1,494
    114
    I'll have another look John :thumb:
  13. Tony Santara
    Jul 26, 2007
    1,494
    114
    Hi Pat
    yep appears to be getting 240 feed i can hear it humming, and automatic changeover
  14. Tony Santara
    Jul 26, 2007
    1,494
    114
    Geo you've got nowt to come,,, :Rofl1::Rofl1::Rofl1:
  15. Bryan
    Bryan Read Only Funster
    Jul 19, 2007
    2,096
    342
    That's 'cos I'm having it, ey? ey? That's right, innit Tony? :Wink:
  16. Tony Santara
    Jul 26, 2007
    1,494
    114
    Noooowa
