Changing the tap
Discussion in 'Motorhome Chat' started by Augusta08, Dec 1, 2015.
  1. Augusta08
    Augusta08 Read Only Funster
    Aug 25, 2015
    59
    36
    Morbihan
    SWMBO complains that the sink is too shallow for a washing-up bowl, so I thought I could change the tap which is currently fixed for one that either extends upwards or is simply higher.
    Does anyone have any ideas how this could be achieved?
  2. hilldweller
    Dec 5, 2008
    26,903
    25,759
    Macclesfield
    Show us a picture.
  3. Augusta08
    Aug 25, 2015
    59
    36
    Morbihan
    DSCF4093.JPG [​IMG] [​IMG]
  4. Augusta08
    Aug 25, 2015
    59
    36
    Morbihan
    DSCF4090.JPG Struggling a bit o get pictures to show.......................
  5. scotjimland
    Jul 25, 2007
    28,934
    25,589
    that's a standard height tap.. how high does she want it to be..
    besides , it swivels out of the way, tell 'er to buy a shallower bowl.. :whistle:
    • Like Like x 1
  6. Figaro
    Figaro Funster
    Feb 22, 2011
    912
    729
    Newcastle under Lyme Staffordshire
    Do the washing up for her ?
    :LOL:
    Ok, keep looking at taps until she forgets about it
  7. wingman
    wingman Funster
    Feb 10, 2013
    985
    2,491
    Romford, Essex
    Perhaps buy a 'swivel spout mixer' that's a similar height, but swivels and 'swings' out of the way of the basin. A company called Reich do them (but there are others :)). Not cheap (£50+) but will do the job.
    Can't quite see from your pic if there's any microswitch wires leading to your tap, but if there are, it's probably just a case of one tap assembly off and drop the other one in. The assembly is normally screwed and held by a base plate underneath the worktop. You may be able to use the original hot & cold 'tails'. If not, the tails can be bought separately. A phone call to fellow Funster @Johns_Cross_Motorhomes is someone who could give advice.
    Looks like you've got pretty good access, so should be a breeze. I've fitted similar to a previous MH of mine and a plumber, I ain't!!!
    Let us know how you got on.
  8. icantremember
    icantremember Funster
    Sep 2, 2010
    5,214
    7,337
    Nr Watton in Norfolk
    I think it's time you change SWMBO ;) .....
    We have exactly the same tap plus a Nature Pure "faucet" over the sink in our Augusta, both of which swivel out of the way if required.
    'er indoors also uses a small plastic bowl in the sink without any problem although she complains about almost anything else.:rolleyes:
  9. Augusta08
    Aug 25, 2015
    59
    36
    Morbihan
    Thanks James for your helpful comment, it would be handy if the height permitted the rinsing of any item. We have become used to having twin sinks in our home kitchen and when space is at a premium it's not always possible to do the whole lot sequentially. It's a small matter the Autocruise Augusta has the 'novel' sink on one side of the van work-surface on the other. That feature was corrected on the later Swift version.
  10. hilldweller
    Dec 5, 2008
    26,903
    25,759
    Macclesfield
    I reckon you could make a spacer to raise that an inch or so.
    Some ali pipe the right diameter and bodge the mounting screws.
  11. Augusta08
    Aug 25, 2015
    59
    36
    Morbihan
  12. scotjimland
    Jul 25, 2007
    28,934
    25,589
    you're spoiling her.. :rolleyes:
    is she's not happy ..tell 'er to use the site facilities.. :LOL:
  13. Augusta08
    Aug 25, 2015
    59
    36
    Morbihan
    Not many facilities on some of these French Aires.................. I always try to spoil her................It would take to long to train a new one.
    • Like Like x 1
