Changing Leisure battery
Discussion in 'Solar Power' started by Billy23, Jun 30, 2016.
  1. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    On a planet...far, ....far away.
    I want to change my leisure battery, is it OK to just take the old one out and connect the new one? Or have I to cover the solar panel to stop it charging whilst I change it?
    As you can see....I know niffin about electric so I would appreciate help as I dont want to "Blow" anything.:)
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,138
    15,084
    Leeds the one up North
    drop the solar +ve out of the regulator until the new battery connected.
    • Like Like x 1
  3. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    Thanks for the reply. I am very sorry but what do you mean: drop the solar +ve
    As you can see I know NOTHING about Solar or electricity.
  4. Techno
    Jul 28, 2010
    14,138
    15,084
    Regulator has two wires from battery and two wires from solar panel. How much simpler can it be. Have a look at it it should become obvious.
  5. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    Oh, penny might have dropped, do you mean take out the wires from the solar panel in the regulator?
    • Like Like x 1
  6. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    Thank you again for your reply. Oh that I wasn't so thick, I apologize solar +ve meant the 2 wires from solar panel. How much simpler could it be.
  7. Techno
    Jul 28, 2010
    14,138
    15,084
    No it just means the +ve rather than both +ve & -ve
    A benefit of that is that if you only disconnect one wire you cannot reconnect them the wrong way around. Or if there is a fuse in the solar cable pull that instead.
  8. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    Thanks, I will look for a +ve whatever that is :)
    I know thick or what, you would have thought that in my 76 years I would have learnt not to be a silly old git......but I haven't :LOL:
  9. Techno
    Jul 28, 2010
    14,138
    15,084
    Hats off! 76 is an achievement in itself (y)
    • Like Like x 1
  10. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    Yes and thank you. I just didn't like the alternative :LOL:(y)
    • Funny Funny x 4
  11. vin0114
    vin0114 Funster
    Feb 8, 2014
    779
    788
    Sheffield
    Billy, the +ve in simple language is the positive cable (usually red outer covering) that goes into your solar regulator from your solar panel(s). You only need to dsconnect that one.
    • Like Like x 1
  12. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    OH! Right, thanks for that, the last VE I saw was when I was a kid, something to do with Hitler. I feel better now. :)
  13. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,932
    2,295
    Lincs
    Both the wires from the panel will probably be black, but the two slots on the controller they go to should be marked +ve & -ve or just + & -.
    + or +ve is short for positive
    - or -ve is short for negative
    The wires that run from the controller to the battery are more likely to be red & black (in a UK van) but can be brown & blue. The battery itself should be clearly marked.
    When changing the battery, disconnect the negative first, then the positive. Then when reconnecting, positive first & finally the negative. Less chance of a dropped spanner causing a big flash. :Eeek:
    • Like Like x 1
  14. vin0114
    vin0114 Funster
    Feb 8, 2014
    779
    788
    Sheffield
    Yes thanks @TheCaller for clarifiying, that. My solar cables had to be extended so black and red cables were used to complete the connections.
  15. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    Very very informative thank you.
  16. Techno
    Jul 28, 2010
    14,138
    15,084
    (y)
