Changing Layout
Discussion in 'Motorhome Chat' started by 6pm Cowboy, Nov 18, 2009.
  1. 6pm Cowboy
    6pm Cowboy Read Only Funster
    Jun 26, 2009
    954
    South Oxfordshire
    Layout is everything
    Ok, I've got the message.
    But given that a van is (say) 15 years old would it really be so bad, or difficult, to change the existing layout of a van to achieve just what you want ?
    Wouldn't be quite the same as doing a total van conversion would it.
  2. Ralph-Dot
    Ralph-Dot Funster
    Aug 1, 2007
    1,067
    35
    Billingham
    I suppose not and see no reason (except cost) for not doing it.
  3. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    Hi Graham, it all depends on what you are changing to where ? from where ? I would recommend leaving the bathroom where it is :Rofl1: then change around what ever :Cool: but then again you will have to leave the boiler outlet in sits as well as the fridge vents,roof vents ? The list goes on :Eeek::Rofl1: RIP it all out and start from scratch :thumb::Doh::cry::Eeek::thumb:
    terry
  4. hilldweller
    Dec 5, 2008
    27,769
    26,857
    Macclesfield
    It's a home. Consider the work at home to move a wall. You can do anything if you throw enough money at it.
  5. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    940
    cheshire
    a good layout is one that works for you, with most layouts you have to come to a compromise somewhere, what works for one doesnt for another. If you go and look at it, sit in it, look carefully at all the angles imagine using it, to try and see what would and would not work. check the bathroom make sure you can shower ok as in able to turn round whilst having a shower without falling over the toilet or hitting the sink. if its a overcab roof bed layout make sure you can both get in and out ok, if its converting seats to a bed back to seats check its not too hard or too much to do everyday, and dont forget the usual if the layout will work and you like it ask to check that the fridge,boiler,cooker,heating all work and that there is no damp or funny smells, check the service record and what belts need doing and when, check its tyres not only for tread but for year they were made, if it checks all those for you then its time to test drive and check the gear selection is ok and it steers true etc.
    I am assuming that you are going to have a look at this one you have found, if so I hope its the one for you, you have been very patient in your search
  6. ArenqueRojo
    ArenqueRojo Read Only Funster
    Nov 10, 2008
    261
    Anywhere in Europe, so fa
    We did a fairly radical refit on our Pilote which might be of interest to you.
    The only thing we didn't touch was the loo - which irronically was what made us change vans because it was too small for fulltiming.
    Cost was about £5,000 on a van worth about that but it was still worth it because we had the layout we wanted at a lot less than replacement costs.
    On top of that, I knew every inch of the van and exactly how everything worked. Also most of it was then new.
    Some piccies in our blog at The Refit « Liz & Patrick’s Travels
    Best of luck
    Patrick
