Changing battery's (1 Viewer)
Jul 10, 2016
414
385
hucknall
Swift bolero 712sb
10 years
Hi.
On an autotrail miami 2007 would it be OK to change the 2 x 85ah battery's to 2 x 110 ah battery's . There is space to do this.
The battery's are wired seperated to the control panel and there is a 100w solar panel
Jaws
23,836
72,455
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Yep.. no probs at all
tonka
10,829
21,524
Cannock, Staffs
A class Burstner 800
Since 2000
Yes, as long as you have space no problem. Charger will be fine.
I have AT and 2 x 110 amps..
NOTE... Remember solar may still be live and charging even with control panel off.. So best idea is cover over the solar while you are doing it or remove any fuse between the panel and regualtor / sargent unit.
Jaws
23,836
72,455
Thetford Norfolk
C class, Chieftain
Or you could go straight to Alan from Direct Motorhome Services ( http://www.directmotorhomeservices.co.uk )
He stocks Banner, is a Funster so you get a discount, and you will know what you are getting is what you thought you were buying :)
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Probably stating the bleeding obvious here but are you changing like for like with the battery technology? ie Lead Acid for Lead Acid, Sealed Lead Acid for Sealed Lead Acid, AGM for AGM and so on?
If not, it'll be worth double checking that your charging system is able to cope with the change. I recently swapped the factory-fitted 95 Ah Lead Acid for a 140 Ah Sealed Lead Acid and I was OK, but everything I read online suggested I couldn't have gone to AGM due to its different charging needs, so I didn't. The option wasn't there on the charger.
