Changing Batteries...??
Discussion in 'American RV's' started by old-mo, Nov 9, 2010.
  1. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,901
    39,916
    My two new leisure batteries are due today.
    What should I look out for and is there a sequence when changing them.
    Do I join the two together before connecting to the positve/negative wires ?
    Or does it not matter which way I put them on ?
    The old ones are as flat as a pancake.
    Is there anything I should Isolate or switch off ?
    sorry for the questions, but as you may have guessed from previous questions, I know nuffink about electrics. :Blush:
  2. hilldweller
    Dec 5, 2008
    27,505
    26,587
    Macclesfield
    Check liquid levels while you can easily.
    Yes turn everything off - then you'll not be frighted by a bit of spark.
    Connect the earth/ground/negative last then if your spanner touches metal whilst tightening the + you'll not get BIG sparks.
    Coat everything in vaseline before connecting. No not yourself, unless you're into that sort of thing.
