Changing base vehicle lights to LED?? (2 Viewers)
Feb 24, 2013
13,054
101,387
Bolsover, Derbyshire
Hymer S800
not long enough
Following on from a recent thread relating to exploding Hymer headlights
I have one the same and so far have not suffered the £1300 repair option !! :)
One thought seems to be the very hot daytime running lights might be to blame, they are 21W bulbs, the same as fitted as reversing lights, but they run all the time with no option on the dash board controls to turn off other than removing the bulbs, which I think I might do
As a better solution can you simply fit a LED equivalent bulb in same holder?
I know at home we have had issues with transformers needing to be changed, but have already changed all the internal lights that we could to LED
Has anybody done this on the chassis lights?
Ours is a Mercedes by the way (y)
Doctor Dave
463
1,110
Wiltshire
None
7 years followed by a break of 11 years and then 4+ years but given up now
Years ago I had a Volvo and there was a fuse to take out if you didn't want the day running lights on.
Dave
Nov 4, 2011
5,920
38,676
Uk
I think you should be able to turn the DRL off, on my Peugeot 107 you can due to some country's not allowing them.
Xabia
1,186
821
Rural Nottinghamshire and Spain
Since 1996
For some reason my running lights on a B544SL have not been working for some time. I presume that the bulbs have blown but in view of the heat issue I haven't bothered to investigate. No bulb warning signs have appeared, they did when a rear bulb failed so it looks like the are not connected to the failure notification system.
scotjimland
2,256
9,780
A Woosh bang
Sep 23, 2013
2,583
8,736
Lincs
Globecar Campscout
Quite agree, you should be able to turn them off, but on some vehicles you can't.
Generally, I like my DRLs on, but there are times when I want to be able to have the ignition key in the 'on' position (with or without the engine running) without looking like a bl**dy Christmas tree to the rest of the world.
According to the manual, I can turn them off, but my 2013 Fiat Ducato insists otherwise. The option on the menu described in the manual does not exist on the actual vehicle.
Jul 29, 2013
9,067
18,425
Salisbury
Hymer B678DL A class
since 2011
I have checked in my Exsis and there does not seem to be an option to turn them off,on my old Autotrail there was an option on the Fiat mode button on the dash but they seem to not have that facility on the A class builds.
Would really be interested if someone finds an LED to fit or a switch to turn them off
Jul 29, 2013
9,067
18,425
Salisbury
since 2011
Try the Mode button on the dash and scroll the menu like I said there was an option on my Autotrail.
Sep 23, 2013
2,583
8,736
Lincs
Globecar Campscout
That's what the manual says too. Only trouble is, the option isn't there. Looks like it was there on 2012 models, but later removed.
Jul 29, 2013
9,067
18,425
Salisbury
since 2011
Found these on ABD.co.uk
382 Twenty20 92 LED 12V P21W Canbus Bayonet Bulb
Customer rating:
Broken Link Removed Broken Link Removed Broken Link Removed Broken Link Removed Broken Link Removed (4.7) 83 reviews
Description
Delivery Prices
Reviews (83)
Specifications
Special Offer
Buy one for £15.50 or a pair for £29.99
These LED bulbs are an easy-to-fit, direct replacement for existing filament bulbs. They also have a considerably longer lifespan, draw less power, generate less heat and are FAR brighter than standard bulbs!
These bulbs are CAN-Bus compatible, meaning they can communicate with the ECU on modern cars, meaning the correct bulb behaviour, and preventing the bulb-out warning lights on your dash. In addition to all these benefits, they also have a much better vibration resistance as there is no filament to break, as well as a much faster response time.
LED bulbs outperform standard bulbs in every possible way, and for peace of mind, every bulb we sell is backed by our guarantee, having endured rigorous in-house quality tests.
The best place for LED bulbs is ABD.co.uk, and the best time to buy, is now…
TheBig1
17,604
43,079
the way to fool a canbus lamp failure circuit is fit a resistor for each 'bulb' replaced. the leds which are advertised as compatible already include the resistor so are simple to replace but much more expensive
DavidG58
Feb 24, 2013
13,054
101,387
Hymer S800
not long enough
Customer rating:
Description
Delivery Prices
Reviews (83)
Specifications
Special Offer
Looks like a good find thanks, not too sure about the much brighter bit though, 21W mounted about 1m off ground is plenty bright enough already for oncoming cars, I am prepared to be the guinea pig here
I have been right through my console options for lights and definitely can't turn them off there, but like @Xabia I got no warning lights on dash when mine went, only noticed when up behind a van could only see one light in reflection
9,067
18,425
Salisbury
since 2011
Trouble is I would not know where to start or what resister to fit so probably the best solution for me is to get some of these.
Jul 29, 2013
9,067
18,425
Salisbury
since 2011
I have been right through my console options for lights and definitely can't turn them off there, but like @Xabia I got no warning lights on dash when mine went, only noticed when up behind a van could only se one light in reflection
Let us know how you get on,I will try and find some lower wattage.
Jul 29, 2013
9,067
18,425
Salisbury
since 2011
These are £19.99 same company and not quite so bright read the reviews
233 ABD 2 LED 12V T4W Canbus Bayonet Bulb
9,067
18,425
Salisbury
since 2011
Have ordered a pair of these will let you know how I get on as soon as I have them fitted.they were £1.95 for delivery so not to expensive.
DavidG58
Feb 24, 2013
13,054
101,387
Hymer S800
not long enough
Thanks, is your Hymer on a Merc chassis as well?
Are your existing DRL 21W?
Will await your report with interest (y)
May 12, 2011
1,187
1,868
West Midlands
Hymer
On my 2009 Fiat based Hymer, I took the DRL's out when the glass shattered, and there are no warning lights.
I had a couple of these from another car project, just tried them (arms are now scratched and shoulders wrenched)
and they seem to work, will have a better look tomorrow, no canbus.
Ebay Item 371207069655
Mar 23, 2012
9,532
31,993
sleights
c class
Presumably if they include a resistor the total power usage is the same as is the heat!!
Jul 29, 2013
9,067
18,425
Salisbury
since 2011
They say in the description that they are cooler.
Jaws
23,832
72,344
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
On one of my bikes had the same issue and agree with Wino..
My answer was to simply replace the bulb in question with an LED version and fit a loading resistor downstream a bit, away from the bulb holder.
Actually, thinking about it, I have a huge pile of the resistors ( suitable for 21w replacements too ! ) still..
If anyone wants a couple just shout.. Free......
DavidG58
Feb 24, 2013
13,054
101,387
Hymer S800
not long enough
Thanks John
I am almost certainly going to opt for the more expensive bulb already sorted (or at least trust the supplier that they have been :D)
It is hard enough just getting your hands on the bulb in my MH, the idea of cutting wires and reconnecting with components and risk of water ingress etc etc fills me with fear :)
But very generous offer for those with an ounce of capability :D
Sep 23, 2013
2,583
8,736
Lincs
Globecar Campscout
Do you need to David? You said that you don't get any warning messages when a lamp fails, so it doesn't look as if you are going to have any CANBUS problems whether the new lamps have the resistors or not.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
But if the resistor has to draw enough current to fool the CANBUS then you get the same heat problem as before unless you mount the resistor/s some way away on long leads. If the resistor is built into the bulb there is no benefit.
DavidG58
Feb 24, 2013
13,054
101,387
Hymer S800
not long enough
I don't really understand electronics, but can't imagine the resistor can get as hot as a 21W filament bulb that would take your skin off if you touch it. when lit or just turned off of course :)
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
21W is 21W. As long as the bulb is not touching or focussed on the headlamp then all that counts is 21W in a confined space, a bulb or a resistor will reach just about the same air temperature.
These makers may know that CANBUS needs only 10W to believe the bulb is OK and in that case you would be on a winner. Suck it and see, it's a cheap enough experiment.
