Chains or not? (1 Viewer)
Craig Rogers
646
412
Midlands, UK (Welsh!)
Newbie!
We are off to Brugge on Saturday, staying at Camping Memling. I'm not sure how much they will get, but it's looking like the snow might be heavy in Belgium on Friday night.
We've no chains (or never used them), apart from the ring road and road out to Memling, it'll be Motorway all the way? Do I rush out and get some chains (not sure where you can get them in the UK quickly) or what do you think about snow socks?
If I'm right doesn't France have a mandatory requirement for chains when needed? Of course, I'm moving through France to get the Belgium, but again, all on Motorway.
Just wondered what peoples thoughts are?
EDIT: Ah well, just realised that I can't fit chains anyway as the tyres are too wide on our MK7 Transit, so it'll have to be socks or nothing.
43,327
49,441
socks will last two minutes on a wet road so be prepared to fit and remove often. !
chains are designed to cut through/into ice to gain grip and will wear quickly on fresh/soft snow
Craig Rogers
Craig Rogers
646
412
Newbie!
Thanks for the help.
Towequip have some socks to fit and they are not too far away, so I'll collect them tomorrow.
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
I would not be too worried heading to Brugge....
I lived in Northern France for over 10 years. Never saw anyone use snow chains.
Also the main routes are normally reasonably well looked after.
Also freshly fallen snow directly onto the roads is not really what chains are meant to work on.
I would definitely consider decent socks, but only to make sure you keep your little tootsies warm as toast....:thumb:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
A bit of an oversight on Fords part!
I suppose they wouldn't expect buyers in colder climes to go for a FWD chassis for commercial use.
If you need more traction, you could make everyone get into the overcab bed!!!!!::bigsmile:
Have a good trip Craig.
Craig Rogers
Craig Rogers
646
412
Newbie!
:thumb:Thanks! Really looking forward to it as it's our first across the water.
Ford states that if you have these tyres fitted, then for chains, you must change to the smaller 195 tyre.
The fact that there isn't even any signs of snow this morning, they may have over estimated. Looks like the forecast for Belgium has changed too.
In the meantime, I'm also trying to find out if these fit -
6,296
22,452
Balma (next to Toulouse) France
HymerCamp 51Capucine
Since 2011/owner since 6/03/2014
You should be able to find a whole thread about the chains. The thread was opened by Haganap. So just ask for an "advanced search":winky:
If you feel safer to have chains with you then just buy them , no matter what is the law.... don't you think??
NO ! If you are on motorways you don't NEED (law only!) to have chains fitted on your wheels ! If you escape from the motorway (and you never know what might happen...) and find yourself in a moutains area , then you might have to have chains with you , in case some local rule obliges you to fit them . Now if you don't have chains with you , and such a case happens , then , you will just have to turn round and change route!
Hope it is clear enough:Smile:
I , as a car driver , don't care. If it snows where I want to go , well I don't go . Unless like last year i have an important thing to do . So last year I crossed all the country to move my daughter to her new flat in Paris ...... Been driving AGES..... at 20kms/hour without chains:Eeek::Eeek:
Amicalement
:Smile:Frankie:Smile:
M1TCH
258
100
East Midlands
Coach Built
I have a set of chains for our MK7 never had to use them though but bought to go to Switzerland for christmas a few years ago, its twin rear wheels and they go on the outer set Gray.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
If the roads are so bad that you need to chain up to travel,my suggestion is park up and put the kettle on until the snowplough has been through. I bought snow-chains when I first started motor-homing years ago so that I could transit Andora. Have never used them since. If the roads are that dangerous that you require snow-chains to move,its best not to. I can understand carrying chains in a car,but not in a motorhome. You have all the conveniences of a house on wheels.
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
My answer to this problem is to make sure you are so far south for the winter that chains or no chains is not a subject you need to think about.
Doug...
M1TCH
258
100
East Midlands
Coach Built
I was informed it was the law to carry chains between certain dates in certain countrys i dont think i would want to chain up its a pain so agree with the above if you need chains dont move it can go wrong rapid id rather drink tea anyway :thumb:
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
If anyone's in France and wants to pick up a cheap set of chains, try a Troc. I was in one in Perigueux last week. About 9 sets, all in cases or original bags at €5-€15.
I've got a set, no idea how I'd fit them alone and like others would park up & put the kettle on.
spannermanwigan
392
207
wigan, lancs
coachbuilt
since 1973
No France does not have a mandatory requirement for snow chains, except in Mountain areas
eg. Alpine regions, and then only on certain roads, which are normally signed to advise before entry.eg. final aproach to Mont Blanc Tunnel.
Dont think you would be looking to purchase chains for your journey to say Dover, as I presume this is your port of exit. You certainly wont encounter roads any more difficult to
transit on your short trip to Brugge.
Regards
Steve
Jul 4, 2010
1,194
804
Essex / central France
Hymer Star Line 680
9 years
Craig, if you think how you would approach the threat of snow in the UK it would be similar to how to behave in most of France and Belgium, it's that simple.
As written, it's the Alpine regions that have chain requirements in certain conditions, but not all the time in all alpine regions.
If the conditions arise you are advised that a few kms ahead chains will be required so you have the option to turn around or fit chains.
