CENTRAL LOCKING
Discussion in 'Tech/Mech General' started by Robbo, Mar 7, 2015.
  1. Robbo
    Robbo Read Only Funster
    Sep 22, 2014
    25
    5
    Milton keynes
    I have a Swift Bolero and the Central Locking on the Habitation Door is not working, but it works on the Cab doors. Does anyone have any ideas what the
    Problem could be. It is under warranty but I am in Spain at moment.
    The alarm still works, but have to lock Hab door with key. Happy Motohoming.
  2. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,801
    1,025
    Cark, Cumbria
    Most of the hab door central locking get their power through pin contacts near the edge of the door & these need cleaning up from time to time.
  3. Robbo
    Sep 22, 2014
    25
    5
    Milton keynes
    Thanks will give it a try in the morning
  4. sweetie
    sweetie Funster
    Apr 14, 2008
    178
    110
    Cromer norfolk
    I had the same problem with bessacarr E745 , It was a broken cable where it entered the door. It happened after swift had carried out work on van.
  5. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    when you cleaned the pins up put a dab of anti seize / copper grease on them or equivalent electrical grease
  6. WillH
    WillH Funster
    Feb 9, 2008
    1,689
    1,380
    SW Scotland
    I had this problem. Stripped the door entirely and found that a small coil spring on the locking mechanism was bent. Very fiddly job but the dealer had 3 goes over 3 years at it and couldn't fix it under warranty. I believe your van is almost identical to mine so it may be the same problem, poor assembly.
  7. Robbo
    Sep 22, 2014
    25
    5
    Milton keynes
    Thank for all your help found the fault a broken wire under seat
    Thanks again Robbo
    • Like Like x 1
