censor on fresh water tank (1 Viewer)
Sep 26, 2013
14
5
denby derbys
rapido 7099f
Hi to all rapido owners can anyone help, were is censor on freshwater tank mines not reading correct and how easy are they to change Regards Dave
Jan 22, 2013
1,241
57,849
London SE
A class Adria vision I707
since 1971
You shouldn't talk about it because it's censored :ROFLMAO:
The water level sensor is normally on top of the water tank by the large inspection cap,
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
It is a useless gadget that never works for long in any van. When water comes out of the tap you have water when it stops you have run out. works every time:ROFLMAO::ROFLMAO::ROFLMAO:
Apr 27, 2008
11,778
13,879
Eastbourne East Sussex
Hymer low profile
Since 1972
Its in the middle of the tank on the top between the two inspection covers. It's glued in so probably not intended to be replaced easily.
Worth trying cleaning the sensor rods with a scouring pad through the inspection covers first.
These sensors aren't very good or accurate even when they work.
Feb 16, 2013
19,447
50,905
uttoxeter
ambulance conversion
50 years
Just fill up when you have chance and ignore the gauge:thumb:
Techno
Jul 28, 2010
15,475
20,752
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Yours will be a CBE sensor unit and they do fail.
You will find it on top of your water tank circular and white . It will have a reference number on it that must be used to order a replacement.
Marcle Liesure stock most if not all at around £30 plus delivery.
I replaced one recently for a FUN member and it was an immediate transformation
Every 12 litre watering can increased the reading by 10% so quite accurate and Karen was quite elated :roflmto:
Techno
Jul 28, 2010
15,475
20,752
May 2010
Example of a 7090f
EDIT no they are very definitely NOT GLUED IN :ROFLMAO:
It is retained by a locknut on the inside and if possession of the appropriate tools is a NO then improvisation can win the day
Techno
Jul 28, 2010
15,475
20,752
May 2010
Ideally this would be better placed in the rapido forum but as the whole of FUN is going to undergo a software transition it's probably best to skip it for now.
Apr 27, 2008
11,778
13,879
Hymer low profile
Since 1972
Example of a 7090f
Apologies Techno, I'm sure you're right. It's just that it's lack of visible fixings lead me to believe it.
Techno
Jul 28, 2010
15,475
20,752
May 2010
No need for apologies matey
I had to pry out the white sealing gasket that you can see through the holes in the perimeter and run a 12" hacksaw blade right through with the blade in the 45 degree position in the frame. This left some white plastic debris inside the tank but not a major job to clean out. I fitted the new gauge hand tight, much easier to replace than remove.
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
I have found a small calibration screw on mine (under little green sticker ) put 25 litres in adjusted till guage read same now not to bad reading. Having said that its only the last 20 or so litres I am interested in for traveling between aires etc .
Oct 21, 2019
297
321
Marlow, Buckinghamshire
Carthago C-Tourer
Begun travelling the road in our first van in 2013
Interestingly our gauge is 13+ years old and has always been really accurate, until this last fortnight when it has decided that 60% is the new 100%. I am going to try and calibrate ours tomorrow (Sunday) all being well and will feedback accordingly.
