Cello 12/24 V tv (1 Viewer)
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
i have a cello 12/24 v to/DVDs combo.
We have tried to watch a dvd tonight on 12v and it won't play
We have previously watched a DVD on hook up with no problems.
Not sure if I have a problem or it's the norm for it not to play on 12v ??
Jul 29, 2013
9,071
18,520
Salisbury
Hymer B678DL A class
since 2011
Ours sometimes doesn't work properly if leisure batteries are low on power usually sound goes.just a thought try the source button check that it's not been changed
461
377
Lincolnshire
PVC, S&L Iveco
45 years
The Cello doesn't like low voltage. You can get an Amperor 12 volt stabilised supply which will give a constant 12v right down to around 10 volts.
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
Back up to 12 volts all working ok :)
I think I will have to look for a alternative when I get home
DanielFord
3,020
3,086
Playing a DVD uses more power than just watching telly, it has to spin the motor. We are very happy with ours, and have used it for extensive periods without a hookup.
Have you thought about a second leisure battery to prolong life off hookup?
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
yes but not sure where to locate it ???
elddis 140 08 plate with room for one battery
11,589
25,417
South Wales
Coach built Adria
we have a cello 12v; there is only one thing to say about them IMHO their NAFF! :swear2:
sound is crap; the screen failed at 3 months old; the remote has to be inches from the screen ( thats even after it got changed and the tv "sorted "! the picture is " adequate"! :restmycase:
would not buy another; hope it dies soon:doh:
DanielFord
3,020
3,086
Is that a u-shaped lounge with the battery under one of the sofas? If so, how about under the other sofa? We have a sundance 630, there is even a holder for a second battery under the other sofa. We are having the second battery fitted next month.
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
Yes battery under sofa but it's not accessible from inside
It's in a sealed Plastic cupboard from the outside
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
W
What would you replace it with ?
Must admit sound is ok,but it's the viewing angle is shocking
If you are not sitting upright it's impossible to see the screen without shadows
11,589
25,417
South Wales
Coach built Adria
W
no sure as yet. we also have an old Avtex which has been trouble free and quite good. its the price that put me off, which is why i bought the Cello. i guess i should have known " buy once, buy well"!:whistle:
so unless i can wriggle something up on the tinternet when i am looking it will be a new Avtex.
Lenny HB
53,427
149,965
On the coast in West Sussex
Hymer B678 DL
The viewing angle although not not brilliant they are quite good compared to other small sets, far better than the expensive Camos in our last van which I swapped for the Cello (put the Camos back in when I sold it). About 4 years old now never had any problems with it. Like most small screens sound not too good, but I always run it via the vans sound system.
Jaws
23,836
72,477
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
We have a 22" Cello Multi and it works ok right down to a battery voltage of 11.5 ..
Perhaps some Cello models are better at handling low voltage than others ?
Reactions: f6c
461
377
Lincolnshire
PVC, S&L Iveco
45 years
W
They do seem to vary, ours is the later 19inch LED version and the viewing angles are good but the sound is very poor so I guess you would not know what you have got until it arrives.
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
We are having the second battery fitted next month.[/QUOTE]
Beware of adding a new battery to join up with an older unit. The experts recommend a matched pair. ie 2 of the same make and model.(y)
Lenny HB
53,427
149,965
Hymer B678 DL
@RS SPIKE does not say which model Cello he has, I wonder if the Traveller range which are for Motorhome/Caravan use have a wider tolerance of working voltage than the other TV's they produce. Unfortunately they don't give a range in the spec.
DanielFord
3,020
3,086
Beware of adding a new battery to join up with an older unit. The experts recommend a matched pair. ie 2 of the same make and model.(y)[/QUOTE]
Indeed, @eddievanbitz (who is doing the work) said exactly the same thing.
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
Its a 22'' Cello C 22230F ??
And now it won't play DVD'S at all so i guess it's faulty :(
