Wombles
Quite a bit of discussion about this Show http://www.ccmshow.co.uk/ at the moment so thought it might be helpful to share some hints & tips to help anyone attending for the first time. Have posted ours below but would welcome any others from Funsters so feel free to post
Parking is included in the cost of your ticket & plenty of room to park the motorhome but not allowed to stay overnight. Car parks are normally some distance away from the main building & as lots of Show halls to walk around so might be a good idea to hop on the free shuttle bus that take you from the carpark to the main entrance but don't forget to note which car park you are in!
Sensible shoes - not just because of the large area that you might cover but also going up & down all those motorhome steps of varying heights safely.
Wear layers as although may be cold outside it gets really hot in the halls with all the lights & people.
Taking a rucksack with food & drinks is a good idea as cheaper & don't have to queue. Suggest only one rucksack if two of you as some manufacturers don't allow them to be taken into their premium models so may have to take it in turns or leave it outside.
There is the option of visiting M&S Simply Food at the nearby airport by walking then using the free Air-Rail link - we did this last year & it's a bit of a walk but easy. Any NEC staff should be able to point you in the right direction as they are normally friendly & helpful.
You can go in & out of the halls freely just don't forget to get your hand stamped the first time you leave. When it's busy & crowded being able to get outside in the fresh air for a break is really good.
Pace yourself - it can be a lot to get around (although the October Show is bigger) & if you have a limited time suggest planning & prioritising the stands you want to see. Suggest downloading the floor plan from here Link Removed on your phone. Also more detailed info. about the stands & larger map at the back of the Show guide - pick up your free copy on arrival.
There is free Wi-Fi so worth checking any prices or information online before buying - some sales staff don't know all the facts or might even make it up to get a sale
Take photos of Show prices & layouts (there are usually boards outside each motorhome) & anything else that you might forget later. It's easy to be dazzled by all the glitz & excitement of the Show.
Ask for a cooling off period with your choice of motorhome held if you do agree a sale - 24 hours is normal.
Be friendly & smile - it's long hours & hard work on the stands so more likely to get a good deal if you are likeable not demanding
