ShiftZZ
Any good?
Dad's PC running like a dog..
Yep like everyone else used it for years but you may find that some web site (including) banks will fail to recognize your PC if you remove cookies - It is not a problem you just get sent a one time code to let the web site know that it is your PC.
I only say this in case you wonder what the heck is going on!
what spec of PC and version of windows?Any good?
Under Options/Cookies you can opt to keep certain cookies so that CCleaner doesn't remove them.Yep like everyone else used it for years but you may find that some web site (including) banks will fail to recognize your PC if you remove cookies - It is not a problem you just get sent a one time code to let the web site know that it is your PC.
CCleaner shouldn't cause that ...Be careful,I used it yesterday on my laptop running Windows 10 upshot was I had to reinstall windows afterwards !
found loads of issues with the registry
The second will probably be caused by the first, especially if the surfing involves visiting sites that download cr*p by stealth. For instance, one can hardly visit a newspaper site these days without being invited to look at photos of how actors from years ago that one has never heard of have changed. Following such links (which appear perfectly innocent) can lead to download of cr*p.Dont unserstand the high CPU use.
What's the harddrive doing?He has Windows 7 and a Dell Inspiron 1524, 2 Gig memory, I have stripped everything off thats not required, run CC and found loads of issues with the registry, all now fixed, run Malware Bytes, found some issues, all removed.. Its still running slow, Task Manager CPU 100% memory fully used..
I am tempted to reinstall Windows... He only uses it for his snaps and surfing... Dont unserstand the high CPU use.
@ShiftZZ - is the PC running an internet security package such as AVG or McAfee? I mean the full paid for version as opposed to the free bits. I find that these packages are an enormous drain on PC resources and if the PC isn't one of the latest, fastest ones then it will run very slowly.
Note that I am not advocating not having any security - just make sure the level of security is sufficient and not OTT.
With 2gig I'd imagine the virtual memory would be getting used a lot, and with a slow drive, or even one that's starting to have problems that would make things slow right down, full memory and high cpu tends to indicate a lot of memory swapping going on.
He gets into a mess, askes people to help who download some strange software. He then denies it. He also switches things off 1/2 way through updates and will click yes to anything. Plus his eyesight is bad.@ShiftZZ ... IMV if it's just started to run slow it could be that something is running in the background - if you go to task manager and check what applications and processes are actually running can you see anything that's gobbling it up?
You can of course increase the RAM memory (assuming it has the capability to take more) but you really need to get to the bottom of WHY it's now started to play up - he hasn't just put Windows 7 on has he?
... is that all ....He gets into a mess, asles people to help who download some strange software. He then denies it. He also switches things off 1/2 way through updates and will click yes to anything. Plus his eyesight is bad.
Definatley a good plan!!Loads of spare room on his hard drive, may try and load 4gb memory... Trip to PC world
