cassett toilet problem
Discussion in 'Tech/Mech General' started by squireh, Oct 27, 2009.
  1. squireh
    squireh Read Only Funster
    Oct 15, 2009
    9
    west lancashire coast
    Hi new member 1st post.Hope someone can help? The pressure release valve has come apart. How do i remove the valve from the holding tank to renew or repair? It is a thetford cassett toilet type c2 or c4. Thanks Keith.(squireh)
  2. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Not 100% sure untill tomorrow but I think you turn it 90' and pull up. But Im sure some one will come back before tomorrow.
    Doug...
  3. Phil
    Phil Read Only Funster
    Oct 21, 2007
    226
    Herts
    When I bought my van the valve was missing from the cassette, I bought one at the local caravan shop. It has to be fitted from the inside on mine so I removed the flap and rubber seal to give more room for my hand. Wore some industrial grade rubber gloves and it slotted into place. Quite straightforward in the end. Just a bit mucky, not for the squeamish :Eeek:
    Phil.
  4. spindrifter
    spindrifter Read Only Funster
    Apr 27, 2009
    43
    This may be of help. Good luck
    HOME
    David
  5. Mick H
    Mick H Read Only Funster
    Oct 13, 2007
    40
    Near Leicester
    I believe that Doug is right. Turn through ninety degrees and pull up.
    Mick H.
  6. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,950
    There are repair instructions on the Thetford web site Here.
    Graham
  7. davejen
    davejen Funster
    Aug 21, 2008
    1,272
    722
    Kirkpatrick Fleming Dumfries
    hi,keith, welcome to the fun site, as you can see already you have had some replies, they will help with anything on here, very good for that.
    Cheers, Dave:thumb:
  8. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    OK Keith, to confirm my previous post.....
    I have checked my C200. To remove the auto vent valve, turn 90' left or right then pull up.
    Doug...
  9. squireh
    Oct 15, 2009
    9
    Cassette toilet
    Hi and thanks to all who replied to my post.Job done Doug was right turn valve left and pull up .Looks like i need a new valve.Once again thanks for your help everyone. CHEERS KEITH.
