cascad water heater (1 Viewer)
Nov 18, 2011
11,862
42,968
Planet Earth
A van
Over 25 year's
the cascade 2 heter in my van semes to run cold after a few min when having shower with gowing wild camping one nead's a shower i am shure the are sum experts out thare :Confused:
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
If it is getting hot and then running cold after 4/5 mins of shower it is time for you to learn the old get wet,turn off lather up then turn on and rinse off routine :winky: or get a trigger shower head to do the same without messing --- you will only get 10 ltrs of hot water which is getting colder the more you use it ::bigsmile: Prob only a 3/4 min shower with adjusting :Smile:
terry
Wildbill
Nov 18, 2011
11,862
42,968
Planet Earth
A van
Over 25 year's
terry
thanks terry thught thay wer like the constant hot water boiler :Doh:cheers
Q answerd
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Q answerd
Through experiance with the Cascade water heaters it is usually the "non return valve" which is part of the "Fulham" connector situated at the top of the heat exchanger, a faulty valve can allow the hot water to run back into the cylinder.
Also it could be the shower head having NOT a big enough rose fitted which slows down the pressure allowing the pump to hunt.
I hope this helps
Regards
:thumb:
Glenn@johnscross.co.uk
