Carver Cascade 2 water Heater
Discussion in 'Motorhome Chat' started by Kevfromwales, Oct 27, 2009.
  1. Kevfromwales
    Kevfromwales Read Only Funster
    May 13, 2009
    30
    Gloucester
    Hi All
    How easy is it to change Burner module for Carver Cascade 2 water heater my gas vales is sticking so I need to look at this winter.
    Kev:Rofl1:
  2. adventure
    adventure Read Only Funster
    Oct 16, 2007
    131
    somerset
    Hi Kev
    Very easy, externally, undo the four cover screws and remove, take off the inner cover, in the right hand lower corner you will see two screws holding the burner module in place, make sure your gas is off and undo the two screws they will not come out then pull the burner module out.
    when you refit it or a new one make sure there are neoprene washers around the screws and also one around the gas inlet
    nick :Smile:
  3. Kevfromwales
    May 13, 2009
    30
    Gloucester
    Thanks Nick that's a great help and sounds easy enough to do.
    :thumb:Kev
  4. MotorhomeWales
    MotorhomeWales Read Only Funster
    Jun 22, 2008
    21
    West Wales
    You will also need to have a gas pressure test once the new burner module has been fitted. This will ensure a correct gas tight seal to the valve on the module. Good practice would bve to also gas pressure test the vehicle before you remove the module.
