Carthago continuously on EHU or not?
Discussion in 'Tech/Mech General' started by Dorset Diver, Mar 6, 2016.
  1. Dorset Diver
    Dorset Diver Funster
    Dec 23, 2014
    373
    189
    Somerset
    The van is fitted with a CBE 516 charger, two 85 amp AGM leisure batteries and of course the vehicle battery. With previous vans I have always left it plugged in and charging when it is "resting" on our drive. They all had Sargent power supplies and no harm came to the batteries but with this CBE I can't decide whether to do the same as the instructions are not clear to me.
    • Informative Informative x 1
  2. SteveandSue
    SteveandSue Funster
    Feb 18, 2009
    362
    95
    Guisborough North Yorkshi
    Hi Dorset Driver
    We have the CBE panel on our van and leave it plugged in all the time - if you are on a site you would have it plugged in all the time aswell?
  3. Dorset Diver
    Dec 23, 2014
    373
    189
    Somerset
    @SteveandSue. Thanks for your reply. I agree with your logic and have been leaving it plugged up I just don't want to damage the batteries.
  4. deanroofing
    deanroofing Funster
    Nov 20, 2011
    290
    250
    bedfordshire
    Plug in all the time.
  5. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,941
    West Norfolk
    The CBE charger will maintain your batteries perfectly.
    However, it might be worth disconnecting the EHU lead and taking off the front cover of the charger.
    Inside is a Gel/PB switch. It needs to be switched to gel to best suit your batteries.
  6. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,043
    11,563
    East Sussex
    I've got a Carthago Chic and would be happy to leave on EHU permanently. We don't need to as we have solar panels
  7. Dorset Diver
    Dec 23, 2014
    373
    189
    Somerset
    We also have a 140w SP but I like to leave the heating set to 5C to prevent freezing which means leaving the EHU connected.
  8. Robert Clark
    Jul 12, 2014
    6,043
    11,563
    East Sussex
    I drain ours down between trips in the winter - and refill just before we go away, with the heating on 20, so everything is toasty before we head off.
    Different strokes for different folks I guess
  9. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    Really? Have never left heating on in a van in 25 years......
  10. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,140
    15,091
    Leeds the one up North
    (y) page 2 English page 5
    http://www.cbe.it/sites/default/files/CB510-516.pdf
  11. Robert Clark
    Jul 12, 2014
    6,043
    11,563
    East Sussex
    I only put it on the day before we leave
    Then on the timer as required
    Hate getting into a cold bed in the winter
    • Like Like x 1
  12. Dorset Diver
    Dec 23, 2014
    373
    189
    Somerset
    In Somerset it is quite unusual for the temperature to drop very low so the frost setting rare kicks in. As for heating the van prior to arrival at site we have an engine heat exchanger that works well.
  13. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,099
    6,090
    West Sussex
    Slightly OT you have AGM batteries but you charger is not suitable for AGM, if you rely on your batteries you would be wise to change them for either wet cell batteries or gel's. I speak from experience having recently had a pair of AGM's fail after 18 months.
    Might be worth contacting CBE to see if there is a mod available for the charger.
  14. Dorset Diver
    Dec 23, 2014
    373
    189
    Somerset
    Lenny, was it established without doubt that it was your charger that caused your AGM's to fail? I ask as it seems strange that Carthago would put them in as original equipment if the charger was not suitable.
  15. Techno
    Jul 28, 2010
    14,140
    15,091
    All the information on the WWW says to treat AGM's as sealed lead acid or maintenance free as the required charging voltages are pretty much alike.
    https://www.batterystuff.com/kb/articles/charging-articles/how-do-i-pick-a-battery-charger.html
    Flooded:
    This is the traditional engine start, tractor and deep cycle style battery. The liquid electrolyte is free to move in the cell compartment. The user has access to the individual cells and can add distilled water as the battery dries out. Popular uses are engine starting and deep cycle designs.
    Typical absorption voltage range 14.4 to 14.9 volts, typical float voltage range 13.1 to 13.4 volts.
    - See more at: https://www.batterystuff.com/kb/art...k-a-battery-charger.html#sthash.alJcch3R.dpuf
    AGM:
    The Absorbed Glass Matt construction allows the electrolyte to be suspended in close proximity with the plates active material. In theory, this enhances both the discharge and recharge efficiency. Actually, the AGM batteries are a variant of Sealed VRLA batteries, just a more advanced design. Popular usage includes high performance engine starting, power sports, deep cycle, solar and storage battery.
    Typical absorption voltage range 14.4 to 15.0 volts, typical float voltage range 13.2 to 13.8 volts.
    • Like Like x 1
  16. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,099
    6,090
    West Sussex
    Most German manufacturers have been doing it for a few years, if you look on the German forums loads of posts of Banner & Varta AGM's failing due to incorrect charging. Hymer have been fitting AGM's since around 2012 and have only just started to fit a suitable charger.
    IMO AGM's are a waste of time in a Motorhome, when I got my new van the AGM's didn't appear to perform very well. I have now replaced them with Gel's the difference in performance was very noticeable.
  17. awg
    awg Funster
    Aug 9, 2013
    209
    234
    Essex
    I park our Carthago I149 at a local farm with all water drained and power switched off at the panel. I bring it home very 6 weeks for an overnight on EHU before taking it back to the farm. Stopped using it in early December and planning to start again next weekend so I only brought it home twice over the winter.
