Carioca fuse box terminal
Discussion in 'CI Motorhomes' started by redpis, Jun 1, 2010.
  1. redpis
    redpis Read Only Funster
    Mar 8, 2009
    24
    Hi Guys,
    I want to use an empty fuse way in the ducato based fuse box, I'm trying to find the crimp terminal which slides into the vacant socket which will allow a mini blade fuse to be used.
    Anyone know where I can get one, tryed local breakers but no joy, internet searches for the part have drawn a blank.
    Any help or pointers would be welcomed
    Ian
  2. 656
    656 Read Only Funster
    Jul 30, 2007
    1,150
    291
    The universe
    Have you tried Maplins or an auto electrician?
  3. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    try fiat they may do a fusebox repair kit.
    i know ford used to or has been suggested an auto electrician may have some.
  4. gazz
    gazz Formerly "gazznhelz"
    Mar 16, 2010
    142
    Eastwood, Notts
    http://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalsnonins/mouldingterms.php
    as for the size you need, that's your guess :Rofl1:
    you'll also need the crimper for uninsulated terminals, it's different to the one for insulated terminals,
    if it were me, i'd nip back to the scrapper with a small flat blade jewlers screwdriver, and pop a few terminals out of a fusebox, snip the wire off a good few inches down the loom, then back home, solder the terminals wires to your wires, pop the terminals in the un-used fuse way, pop in a fuse, and roberts your aunties hubby, (remember to gentyl bend the latching tang back out before you slip the terminals into the fusebox, as they get flattened when compressing them to get em out)
  5. redpis
    Mar 8, 2009
    24
    Hi Gaz
    Thanks for the brilliant link which I will follow up.
    Our local scrappy charges a minimum of £5.00 to go through the gate :-( so thats out!
  6. redpis
    Mar 8, 2009
    24
  7. redpis
    Mar 8, 2009
    24
    Update
    Ok to recap - instead of using scotchlok connectors or cutting and soldering on to a supply cable ( both switched and unswitched needed) I thought I would make use of the spare ways in the fusebox, took a while but with help got their in the end.
    The part number from Vehicle Wiring Produts is 3-8331. this is the crimp receptical which slides into the empty socket to allow a mini fuse to be used.
    I found removing the complete surround from the fuse board made life really easy.
    With the fuse box exposed, unplug the main supply and control cable from the block, undo the three 10mm hex bolts and this will allow you to work on the block.
    On the side of the block is two orange strips, these are the plastic retianers for the top and botton sockets.
    Slide out the botton (blank socket) strip (might need a but of a robust tug).
    Crimp the cable into the 3-8331 with pliers (I soldered for good measure) and push from below into blank hole (check oriantation, the crimp has a small tag to help alignment)
    When new socket is 'home' slide locking bar back fully into the block.
    Re-assemble and the jobs a gud un.
    Hope this helps
    PS I bought loads of different ones before I got the right one, so if anyone needs a few give me a shout
