carioca 656 2009 control panel lights
Discussion in 'Tech/Mech General' started by Daviedubs, Mar 30, 2016.
  1. Daviedubs
    Daviedubs Read Only Funster
    Sep 25, 2015
    30
    midlands
    Hi - I have a red light flashing constantly - see photo - manual says it is a waste tank - but there is another waste tank light system - the flashing light is also part of the engine battery check although this does not light when the test button is pressed - any ideas anybody?
    Regards
    Dave
  2. Daviedubs
    Sep 25, 2015
    30
    midlands
  3. anthony whitstable
    anthony whitstable Read Only Funster
    Jan 26, 2014
    11
    4
    whitstable
    HI THERE MINE ONLY FLASHES RED WHEN ENGINE BATTERY IS FLAT WHEN THE BATTERY BUTTON IS PRESSED BOTH ENGINE AND HAB LIGHTS UP TO SHOW CHARGE HOPE THIS HELPS
    ANTHONY
  4. Daviedubs
    Sep 25, 2015
    30
    midlands
    Hi - had the engine battery replace - this did not change anything - when you press the battery check button the light stops flashing and stays on -
  5. bubble63
    bubble63 Funster
    Aug 10, 2012
    591
    543
    cambridge
    It's the cab/ engine battery indicator
    It thinks the engine battery is flat
    Is the engine battery flat?
    Regardless of when you replaced it , can you start the engine etc
  6. Daviedubs
    Sep 25, 2015
    30
    midlands
    Yes it was a brand new Bosch battery put in and all is good......
  7. bubble63
    bubble63 Funster
    Aug 10, 2012
    591
    543
    cambridge
    mine is a 2007 CI 656, pressing the blue lower left button illuminates both left LED ladders. top left LED ladder gives hab. battery state, when on mains the ladder pulses,
    the lower left LED ladder shows the engine battery.
    So you say you have a good engine battery which operates the engine satisfactory and is not flat, then fault lies with the indicator
    Interestingly that bottom left LED ladder also looks like it can assigned the show a third tank level or engine battery level
    So did it work correctly before you changed the engine battery?
    Have they connected ALL the wires back on to the battery?!
    Has anybody touched the control box which is behind the drivers seat?
  8. Daviedubs
    Sep 25, 2015
    30
    midlands
    This was happening with the old battery which was knackered.....so thought a new battery would resolve it....only had the Motorhome since October so haven't used it much and still learning! What usage control box Behind the seat?
  9. bubble63
    bubble63 Funster
    Aug 10, 2012
    591
    543
    cambridge
    OK
    My guess is that you need someone to look at the control box behind the drivers seat
    It could be set to look for a fluid level and needs setting to cab battery, no idea how to do this, sorry
    Also the box is full of fuses, there is a lid on the top, perhaps check those too
    Also lift the lid on the cab battery, which is in the passenger foot well, and check everything looks ok in there, I don't think there are fuses but there will be the cab feed the the control box, check its intact/connected
  10. Daviedubs
    Sep 25, 2015
    30
    midlands
    Thanks - is the control panel the same on your 07 van? The fridge also will not work on 12v - obviously should only work with engine running - could this be part of the same issue ie not recognising the engine battery?
  11. bubble63
    bubble63 Funster
    Aug 10, 2012
    591
    543
    cambridge
    yes it definitely is:)
    the fridge only works on 12v when the ignition is on , this is to avoid cab battery drain, so my guess is you have lost cab battery to control box power
    I don't think you will get a hab. charge as you drive either, which could be an issue
    check those fuses(y)
    Could I have all the clues at one time please:)
    yes, my control panel is identical
  12. Daviedubs
    Sep 25, 2015
    30
    midlands
    Thanks for all this - you are confirming what my suspicions are!!! While we are on a roll with you - how do you get the heat to come out of the ducting points? They talk about a fan?
  13. bubble63
    bubble63 Funster
    Aug 10, 2012
    591
    543
    cambridge
    You have a pm
