Carbon monoxide (1 Viewer)
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Since 2010 Caravan since 1995
Can anyone help
Last night /this morning 02:35
The CO alarm went off.
The only thing on was the fridge (Dometic.)
I ventilated the motorhome and checked the fridge vents for blockage.
Reset the alarm and all was well.
This morning same again about 11:00.
Then found i had the fridge on full
Turned it down and all as been ok since.
I will go to a dealer tomorrow but is there any thing I should check.
Mel
Lenny HB
52,682
147,573
On the coast in West Sussex
Hymer B678 DL
Sounds like a poor fridge installation, but if the fridge burner is burning with a clean blue flame shouldn't be enough CO to set off the alarm. If it's burning with a yellow flame that is one of your problems the other being a poor fridge installation, as even then it shouldn't get inside the van.
Reactions: Mel
Mel
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Yes I even changed the battery.
Its been ok since.
Just made me a bit nervous
Mel
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Its a 2011 the fridge has never been out.
We where away for 8 weeks with no problem other than it was so hot the fridge was struggling to keep cool
Mel
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Maybe I beter just let the Agent clean it all out this week.
Beter safe than sorry.
TheBig1
17,509
42,755
an over charging (cooking) leisure battery will set of a C0 alarm too
Reactions: Mel
D
Deleted member 29692
Keep it simple. Look at the alarm before panicking about the fridge.
Good practice with any alarm of this type, whether in the MH or at home is to keep it clean so give it a good clean out with the nozzle of a mains vacuum cleaner and you'll probably find it works wonders. This is the solution to 90% of domestic smoke detector false alarms and it's good practice to give them a hoover out 2 or 3 times a year.
As with anything try the simple things before you get over complicated (y)
Mel
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
We had no EHU
And the Efoy was off.
I will check the leisure battery's just in case.
Feb 24, 2013
12,990
101,147
Bolsover, Derbyshire
Hymer S800
not long enough
As above, but please buy a CO alarm, not CO2
IMO the CO monitors with display are well worth the few extra £'s
We have a Kidde one with numerical display so if ours goes off (the house one does due to log burner not being shut down properly sometimes) at least we have a level of worry to work to
I think the alarm will go off at 35 (it think the units are ppm) in reality you need to be well over 100 and for quite a while to cause any harm, I would liken it to a smoke detector, slightly burnt toast can set it off but will never lead to personal harm, but if the grill has caught fire you still get the same alarm
Hopefully yours was low level but you cant be too safe, CO silent, odourless and can be deadly
Reactions: Mel
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
You are absolutely correct David, my mistake.
Brisey.
Reactions: Mel
Mel
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Thanks all I have a kidde but not digital.
I will get one right away.
I cant see the flame but will get it all checked out before using it again
Mel
