Carbon Monoxide Poisoning (1 Viewer)
DBK
18,007
47,990
Plympton, Devon
PVC, Murvi Morocco
I may have a faulty detector......?
It is brand new, I think we got it from B and Q, can't remember. It is a model CO-FA-9B First Alert Carbon Monoxide Alarm.
It went off a couple of mornings ago and woke us from our sleep. I jumped up and opened all the windows etc, then started thinking...... nothing is on except the pilot light on the water heater????
So last night before bed I turned off all gas appliances. Nothing was on.
This morning we are woken by the alarm again. I could not turn it of!!! I removed the batteries and went back to sleep!!!
I am still not dead, so I assume we have no CO in the van, and a faulty detector!
Anyone have any clue what might be going on, or is it really as simple as a faulty bit of electrics?
Might also be worth removing it and keeping it in say a bedroom at home. See if it goes off there. If it doesn't then you must assume there is a problem in the MH - batteries gassing for example as suggested above.
OddSocks
475
386
Cornwall
Newbie
Wow! Scary. Thanks for the help. Not sure what we can do now, in the middle of the Dordogne!!!!
Will experiment and see if I can reproduce the problem, as I can't remember which batter was being charged at the time. Or even if we were on a EHU....?
Al1
49
19
How can I tell if the Battery is gassing/ being overcharged?
Feb 24, 2013
13,049
101,377
Bolsover, Derbyshire
Hymer S800
not long enough
we bought these, not from this supplier we paid just over £20
http://www.safefiredirect.co.uk/smo...rchantcentre&gclid=coyvozohkcecfy_itaod9aoaja
they have a 10 year life, we also fit them in our buy to lets
what I like is the display, which also has a resettable memory allowing a useful look at any small CO recording that may not trigger the alarm
but yes a good prompt possibly the most important thing in our MH
Feb 24, 2013
13,049
101,377
Hymer S800
not long enough
When near the battery and possibly anywhere in the MH you will have a bad egg smell, you will also hear it literally boiling and hissing if you close to it
Do not move it, disconnect charger (turn off at least) and leave well alone for a good few hours
(y)
Reactions: Al1
John & Joan
1,425
774
Darlington
10 years this time
Possible problem with monoxide from Gasparini (now Telco) LPG 2 stroke generators.
We have one mounted under the van behind the rear axel. The exhaust for these just vents under the van. Last week while the generator was running the Alarm went off. I had had the exhaust extended to make sure it was well away from our Truma S3002 heater.
I have had the cover off the heater and can see daylight below the heater from inside . I can only presume as it was still that the fumes had built up under the van and entered through the gap and then distributed by the heat.
GJH
29,450
38,827
None, now sold
2006 to 2022
Bill's winter usage thread reminded me that I noticed yesterday that Asda had some Kidde CO detectors on sale for £12. No excuse not to get one at that price.
I posted the same in Bill's thread but it's so important it's worth saying here as well.
Charlie635
35
22
Stockport
CI CARIOCA
1 Year
Just been to Aldi, they have carbon monoxide detecters for £13.99
Reactions: GJH
Aug 6, 2013
11,950
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
You have nothing to fear from a well maintained system. Get a professional to service your cooker, water boiler and heater. You should have a gas alarm and a carbon monoxide alarm fitted. Again take advice from a professional as to where these would best be located in your particular motorhome.
You are right, sleeping with a gas heater on, even a fully serviced one, is not really a good idea. They can quickly warm a van in the morning though:Smile:
Why?
I'm totally confused by this discussion. Motorhome OEM heaters have no connection with the inside air of the MH. Combustion air enters from outside the van, is mixed with LPG in the room-sealed heater, burned, then exhausts outside the van. If the flue is partially blocked and/or the flame isn't burning properly CO will be produced and exhausted outside the van. If the flue is totally blocked the heater will go out. All this applies to water and warm air heating both of which are designed to be used at night.
The fridge (if it's burning with a yellow flame) will produce CO and has a rather 'informal' flue arrangement and flue gases could possibly find their way into the van. Ovens and hobs produce large quantities of CO2 when burning correctly and don't have flues. If either burn with a yellow flame they're producing CO so it's important they burn blue. And you wouldn't use either at night (I hope!).
Well-publicised deaths caused by CO poisoning are invariably caused by something brought into the living area or into somewhere connected to the living area - barbecues, open flame portable heaters, generators etc. I don't remember reading of a single case of poisoning by permanently installed OEM appliances.
Puddleduck
12,378
43,945
Scottish Borders
Without at present
On and off for many years.
Why?
I'd still rather have a CO detector that take any risk however minimal.
Jim
Jim
Ringleader
Jul 19, 2007
36,316
130,212
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Why?
I'm totally confused by this discussion. Motorhome OEM heaters have no connection with the inside air of the MH. .
Modern ones don't, but older ones burnt the flame right there in the motorhome with you. Hence why the poster I was referring to saw flames.
13,049
101,377
Hymer S800
not long enough
I was just typing virtually the same, but using more words :D
when the original comment was written in 2007 there would have been even more still in use, but I bet a good few MH's in regular use have the more traditional wall mount fire
Anyway CO is invisible and odourless, just get a detector
stevetracey
32
34
Plymouth
I'm a newbie November 2014
Interesting reading and a must. What do you think of this? Do you think its worth the money or go for the battery operated ones?
Broken Link Removed
TheBig1
17,591
42,999
Broken Link Removed
if it works as well as described, an excellent addition to any van or home for that matter
JaG
Oct 30, 2008
1,375
1,458
Chesterfield
Autotrail Cheyenne
Since 2008
i already have a combined one similar to the one above as part of the Sol-Alarm system I fitted when I bought the caravan in 2011. It also picks up narcotics. Pity the company went bust a couple of years ago so I hope I don't get any problems with it.
The link above looks a good option if picks up narcotics as well.
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
  • Within 5 feet of any cooking appliance or kettle.
So it goes outside the van then?
On a serious note of course this is why it's so important to get the right type of alarm. Just any old CO alarm or smoke detector isn't any good.. it has to be meant for the situation you plan to use it in.
robarb38
69
39
Merseyside
Don't own one yet
"since 1984"
There is a very good one for sale in the classified section :whistle:
As well as a really good quality cycle rack. (y)
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I sometimes lie awake staring at the little red flashing light wondering if it is going to go off any second, getting paranoid.
Does it flash as a working check? is it going but the buzzers bust? Must go and put three more in different place and get really worried in my sealed box with a gassing machine with me. I must not read these posts as they worry me too much.
JaG
Oct 30, 2008
1,375
1,458
Chesterfield
Autotrail Cheyenne
Since 2008
Believe me, there is nothing funny about being overcome by carbon monoxide fumes it happened to us and our lives were saved by the alarm - see the link below so you do not have to read all the posts.
The little red flashing light is a self test and an indication that you can see all is well. When the battery is going down it bleeps once every minute to tell you to change the battery. This goes on for a couple of weeks before it finally dies and is very loud so can be heard outside the van.
The narcotics detector's main use if for gas. Have a leak in the van that you cannot detect and it will do it for you. More likely to save you from an explosion than being gassed. These are not gimmicks - they are common sense additions.
http://www.motorhomefun.co.uk/forum/threads/carbon-monoxide-poisoning.2713/page-5
Reactions: GJH
GJH
29,450
38,827
None, now sold
2006 to 2022
I remember that incident Graham. I didn't realise it was as long as 6 years ago though.
Certainly sound advice which everyone should follow.
JaG
Oct 30, 2008
1,375
1,458
Chesterfield
Autotrail Cheyenne
Since 2008
Yes, six years. Scary where time goes so quickly isn't it.
We have one Carbon Monoxide in the lounge at head level, one in the bedroom above the headboard and a narcotics at floor level next to the bed and air vents and at the kitchen end so picks up cooker, etc - just as safety caution as we caravan on the continent.
Reactions: GJH
Oct 29, 2008
5,058
5,911
West Yorkshire
PVC
since 2008
At the Newark show they were giving CO detectors away for free! All you needed was to have either students at home, had a pension age person at home or a disabled person at home.
