Carbon Monoxide Poisoning (1 Viewer)
Denizen
9
Oxford
Upper class
Um?
Hmmmm.. I just invested £115 in the "LINNEPE 3-IN-1 GAS ALARM (RPR-C6903)". Have I wasted my money?
BTW does anyone know whether this is a passive device? For obvious reasons, I don't want to have to switch it on and off all the time, and I am thinking about the drain on my battery.
RuthRv
865
aldi are selling these at present at £3.99 if anyone still needs one:thumb:
ruth
43,328
49,441
ruth
are you sure its a CO alarm and not a smoke alarm ruth,
sounds too cheap for a CO type.
B+Q have them at the mo for £15-ish
i have a combined smoke/CO......cost £35 from B+Q a couple of years back.:thumb:
RuthRv
865
i thought so too, I paid £15 for mine last year on a special offer from lloyds, but i double checked and it was a carbon monoxide alarm, but it is the size of a credit card.
I think they have a web site so take a look, nowt to lose:ROFLMAO:
ruth:ROFLMAO:
RuthRv
865
just been on the aldi site but no search engine on it, sooooooooooooo i a going to go to aldi again tomoz and will check again, in case it has been marked up as a carbon monoxide alarm when it isnt, will let you all know tomoz. if there are any left only lots of people were buying them:Smile:
ruth:Smile:
43,328
49,441
ruth:ROFLMAO:
its NOT an alarm ruth, its an indicator........
plastic card with a spot in the middle....if theres CO it changes to a dark spot.
we tried them and they arent much good.
ours went nearly black in a week near the boiler but neither of the proper alarms triggered.
the dark spot in the middle is supposed to be cream coloured.
i have two alarms cos i dont trust 'em to work 100% of the time.
RuthRv
865
that explains why they are so cheap, 2 in a pack and a 12 month guarantee.
stick to the one from lloyds me thinks:thumb:
ruth
43,328
49,441
the one in the pic has a shelf life of 3 years unopened but must be replaced every 6 months when opened.
could work out expensive...:Sad:
Mavis
Oct 18, 2007
714
488
Seasalter kent
Clubman
It doesnt matter how much they cost as they are a life saver.
They need to have an alarm sounding.
We had a problem with our chimney and on a cold crisp night we left our fire on low and the alarm went off, so it saved our lives.
Ours was bought at Tesco,s for £19.99.
MotorhomeWales
21
West Wales
As part of our habitation service schedule we carry out a whole vehicle carbon monoxide test. The test takes 30 mins and reads the carbon monoxide level every minute during the test time with all the gas appliances running. We also test carbon monoxide levels for individual gas appliances.
Anybody who wants to call in to have a carbon monoxide test carried out is more than welcome, free of charge of course! Just let me know
Its also worth bearing in mind carbon monoxide levels are also high when the flu is cold (when you first light the appliance)
Dan
Carafit Caravan Services
B
BPGas&LPG
For those who don't have a carbon monoxide detector B&Q are doing a portable model for about £15 at the moment. Money well spent if you ask me
The best one are Honeywell SN450 & SN350 - only ones that bear a CORGI badge of approval, run for 6 yrs on the battery that comes with it.
CO gas can be bought to test the sensors also, so that you aren't just relying on pressing a button to ensure the thing is working.
When fitting an alarm remember that it should be placed near where either you are sleeping or sitting watching TV, tiredness is one symptom of CO poisoning, fires are usually the chief offenders in motorhomes,not just gas either, any appliance producing a flame can produce CO that includes woodburners.
oldun
747
162
St Neots
VW Campervan
Since 2001
I have seen it stated on several forums that they should be mounted up high but in the USA they are mounted as low as possible, right at the bottom of the entrance steps.
What do the instructions recommend?
S
sinbad1
There is little difference in density of air and CO so imagine you have your fridge running on gas and your gas heater running both will create a convection current , ie hot gasses will rise to the ceiling then cool an drop down.
Logically in a motorhome
If either appliance gives off CO then the logical position for your monitor would be high up between the two sources .
Regards
errpaul
538
83
Wiltshire
11 yrs
I've heard that there are gas alarms (LPG) as well as CO ones....
Do you then need to have 3 different alarms, smokw, CO and LPG??
S
stagman
The more you have the saffer you will be :thumb:
scotjimland
2,320
10,003
A Woosh bang
and if you are paranoid ....... a Narcotic Gas Alarm :winky:
S
sinbad1
You allready have a gas detector your nose:RollEyes: smells like rotten eggs
Yes you can get gas detectors Link Removed Propane is a heavy gas and will tend to lay low so its important that the detector is sited low also there is ventilation at low level as a build up of gas could lead to a rather large exsplosion:Eeek:
regards
errpaul
538
83
Wiltshire
11 yrs
regards
Thats my view, but Mrs L doesn't see it the same. Guess it's best not to compromise on safety and can definately see the reason for CO and obviously smoke detectors.
M
mattireland
afraid to use trumatic gas heater due to baby
we just purchased a 1998 2,5 tdi ducato cheyenne and gas is one thing that always freak me out , even to the time when getting a tooth out at the hospital in my younger days
and also especially when we have a 3 month old baby, i`m even so nervous of actually sleeping in the motohome with her, i checked the heating system first switched on the gas and got the flame lighting turned the dial and the flame splurted out with a weird sound, i actually nearly fell out the door of the motorhome rushing to turn off the bottle , i have no idea of what could be wrong here, tried again later and noticed a battery pack in the heater changed them not actually knowing what they do, started my heater again got the flame lighting and this time turned the dial to 5 / 6 and after a few seconds the flame splurted out again, there is no way i will go off with my children on our first vacation without fitting a gas detector alarm as i have no idea what kind of heater we have or how it works and definately will not run it while we sleep, can anyone help me out here:Sad:
Jim
Jim
Ringleader
Jul 19, 2007
36,409
130,842
Sutton on Sea, UK
Adria Panel Van.
Since 1988
You have nothing to fear from a well maintained system. Get a professional to service your cooker, water boiler and heater. You should have a gas alarm and a carbon monoxide alarm fitted. Again take advice from a professional as to where these would best be located in your particular motorhome.
You are right, sleeping with a gas heater on, even a fully serviced one, is not really a good idea. They can quickly warm a van in the morning though:Smile:
Tony Lee
274
From where did it splurt out. Inside the motorhome or from the outside vent.
Either way there is a major problem and it needs attention.
Brand and model of heater and an accurate description of what happened would help us help you
JayDee
1,057
169
N. Devon
7 Years after 5 years with caravan.
We've got one of those mutiple sensor gas detectors, powered by the vans 12v supply. The CO detector is mounted on the ceiling. We were quite concerned that, after dinner, when we were quietly enjoying a snifter of brandy, the CO alarm would erupt into screech mode. It also goes off with wifes hairspray.
Apparently this is normal, so it gets regularly tested and prevents us from drinking too much (yeah right!:RollEyes:)
John
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
I took the batteries out of the smoke alarm and the gas detector when I winterised my m/h.
The CO detctor has a huge red sticker on it which says "Replace in 2009".
Ive just had a Habitation check, did the person who carried out the Hab check replace the batteries or even mention them, did he warn me about the CO alarm. NO!!!.
So much for a Hab check
Jim
:Doh:
thepadster
13
Bristol
coachbuilt
not long in this one
elddis autoquest 320
Hi to everyone , hope you are all well and enjoying the nice weather , just wondering if anyone else on here has an elddis autoquest 320 year being 1991 or there abouts , just curious to see if i am alone , ok thats it ,take care
43,328
49,441
posted this in the wrong place padster......
try a new thread in the motorhome chat section.
this is a permenant thread about smoke/gas/CO2 alarms.
Teasy2007
2,086
1,159
Rotherham South Yorkshire
Carthago Malibu PVC
Hi Scotjimlad,
Is there such a thing as a narcotic gas alarm? We are parked next to a dutchman who was gassed in his van last year, they woke up to find the only valuables left were in the shorts pocket he was wearing in bed!
I know there have been many posts on this subject, but thought it was a bit of an old wives' tale until we spoke to our neighbour and his wife!
Ginny
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
During inclement weather I was using the BBQ in the awning with the window opened. Suddenly beep! beep!. Wassat! CO alarm, which I had forgotten was going manic. At least it tested the alarm, on of Lidl's specials.
I.ve fitted it discreetly under the table, and a LPG alarm next to the gas locker.
The smoke alarm goes off when the OH cooks, much to her annoyance and my mirth!
Carbon monoxide is lighter than air so alarm should be fitted as high as possible, if fitted under a table you will most likely be dead before it goes off.
LPG is heavier than air and should be fitted as low as possible.
scotjimland
2,320
10,003
A Woosh bang
Hi Scotjimlad,
Ginny
Hi Ginny
Yes there is, Google should find it...
I don't have one and until such times as irrefutable proof of a gas attack is posted and the gas used I see no point .. just my opinion.
45eEver
267
Carbon Monoxide only doesn't smell (is odourless) when it's pure.
If you can smell something that might be fumes, assume it's carbon monoxide.
Propane is odourless.
They put summat smellie in, a stenchant, so that you can smell it.
It's well nigh impossible to make smell-less carbon monoxide from propane.
Ditto, butane, diesel, petrol, North Sea gas (methane) in fact, all the fuels I can think of.
On the other hand, you won't smell any of them if you are asleep.
Just because there's bit of a smell doesn't mean it's not carbon monoxide.
This is an additional warning.
It is not an argument against fitting monoxide alarms.
Yes, like heads, two alarms are better than one.
Two alarms, and your noses are the very best.
