caravan frodge problem (1 Viewer)
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Have a friend on site with a three way fridge which will not work!
There seems to be no power supply either 230 v or 12v
Any ideas anyone?
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
I haven't got a clue Ken, but of course you could help him eat the contents so that it doesn't spoil...........
..........Sorry.........Griff :getmecoat:
Gellyneck
9,195
18,143
Scotland
More than toes wet now!
Any ideas anyone?
From memory, the fridge only works on 230v and gas. 12v is for when connected to the car and the engine is running.
Is it working on gas?
Is the caravan master switch turned on for the 230v supply?
Are any other 230v items, eg lights (not 12v), kettle, etc working?
Has the MCB in the caravan tripped?
If not, has the bollard tripped?
Still thinking!
Munchie
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Everything in van is working!
Yes it should run on gas but needs 12v supply for panel!
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Are there any lights on the fridge at all Ken? Red or blue or digits in the display
BwB
917
1,170
Suffolk UK
Resting b'twix vans
Since 1990
Had a moho a while ago where the permanent 12v (needed for it to work on any power source) was routed via the Aux supply switch on the control panel. If the Aux was accidently turned off then the fridge wouldn't work.
Maybe something similar?
Gellyneck
9,195
18,143
Scotland
OK. I assume other 12v items are working?
Can you access the back of the fridge through the vent covers? If so, can you check to see if there is a 12v supply to the back of the fridge?
Disconnect the 230v EHU and shut off gas to be on the safe side.
Munchie
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Now established a supply to fridge thanks.
Looks like it could be fridge board.
Leaving to experts now!
Gellyneck
9,195
18,143
Scotland
Glad you at least know where the problem lies.
Nothing worse than not knowing and getting paid assistance to find out the switch was off!:Smile:
Oct 8, 2014
1,544
4,565
Todmorden
Compactline 143
I'm a newbie and always will be. You never know it all.
Would this fridge be a dometic by any chance? Because i'm having exactly the same problem.
Feb 16, 2013
19,696
51,876
uttoxeter
ambulance conversion
50 years
Is it level, makes a lot of difference to some fridges
Mad_Sunday
8
13
Burton, Staffordshire
Self build/Van Conversion
Since 2011
I had issues with a 3 way Electrolux fridge "not working", ie it wasn't getting cold. I googled (a lot) and found the same answer from several individuals. Take the fridge out, turn it upside down for a few hours, turn it back over and refit it! It transpires the chemicals involved in it's design can form crystals, which eventually block the pipes. Turning the fridge makes them fall and disperse into liquid again.
Pete
