Captains chair adjustment
Discussion in 'Motorhome Chat' started by Bill and Pat, Jul 27, 2015.
  1. Bill and Pat
    Bill and Pat
    Jul 6, 2015
    8
    Blackrod Bolton
    Hi,
    Just purchased a burstner aviano, the swivel seats are very stiff to turn, does anyone know if they can be adjusted, also how do you remove the rear plastic cover on the seat base to gain access to the centre swivel.
    Thanks a new member
  2. rapido convert
    rapido convert
    Feb 26, 2015
    58
    113
    knutsford cheshire
    Hi bill and pat,
    Welcome to the happy fun club.
    The seat is secured by a single center bolt needing a 22mm spanner and 24mm socket. Be careful not to slacken too much as you will get wobbly seat syndrome :),
    The swivel plate is sandwitched between a nylon swivel pad it is self lubricating and should not be overly greased/oiled.
    The above is for an Aguti seat but from what i have seen in my various other moterhomes i have owned the same instructions/rules should apply
    Andy.
  3. Bill and Pat
    Bill and Pat
    Jul 6, 2015
    8
    Blackrod Bolton
    Thanks Andy, will have a try to slacken off the bolt a little, did see the bolt and the nylon pads, do the plastic covers on the rear base clip off to give access to the bolt, I tried to pull but didn't want to pull too hard and break the cover.
    Thanks Again
    Bill
  4. rapido convert
    rapido convert
    Feb 26, 2015
    58
    113
    knutsford cheshire
    Depending on the make of seat, Aguti are on trim clips and pull off but i have seen trims held in place with minute self tapping screws from the side,
    Andy.
  5. Bill and Pat
    Bill and Pat
    Jul 6, 2015
    8
    Blackrod Bolton
    Cheers and thanks very much for your reply Andy, will be looking to sort it tomorrow.
